Author: Subject: Live Axle Bracket shock mount suggestions
GaryM
posted on 7/3/05 at 06:52 PM Reply With Quote
Hi Guys
I'm now moving onto fabricating my live axle brackets and the corresponding lower shock mounts.
I would appreciate any suggestions (and better still archive photo links) as to possible solutions other than weling & gussetting a standard U shaped bracket on the top of the axle bracket (as per the book).
Thanks in advance.
Gary
Danozeman
posted on 7/3/05 at 08:00 PM Reply With Quote
Theres the other way in the book where it bolts to the side of the axle bracket. Not sure how its done..
Dan
clbarclay
posted on 7/3/05 at 08:13 PM Reply With Quote
A thick flat plate with a hole would mean you could use a shock unit with turret type bushes instead of bolt through.
posted on 7/3/05 at 08:15 PM Reply With Quote
http://www.locostbuilders.co.uk/viewthread.php?tid=22061
Bolting to the side of the trailing arm bolt is only viable if you use longer shocks.
Also the shocker mounting bolts will work equally well aligned for-aft instead of inline with the axis of the axle.
clbarclay
posted on 7/3/05 at 08:18 PM Reply With Quote
Originally posted by britishtridentAlso the shocker mounting bolts will work equally well aligned for-aft instead of inline with the axis of the axle.
Origional range rovers had the damper one one side lent inwards + forwards and the other side lent inward + backwards.
timmy
posted on 7/3/05 at 10:58 PM Reply With Quote
Check out my lower brackets:
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=RearShockerMount.JPG
I have use a bit of 50x50x4 RHS cut at about 50mm and mounted it vertically with one of the open ends fixed to the axle and the other to take the end of the shocker. I've also used a similar mount at the top and I reckon it's loads stronger than the U-brackets.
HTH,
Tim
phil m
posted on 8/3/05 at 07:53 AM Reply With Quote
same as above ----hole drilled to access bolt
Phil
phil m
posted on 8/3/05 at 07:55 AM Reply With Quote
posted on 9/3/05 at 08:11 AM Reply With Quote
Originally posted by phil m
pic attached this time
very neat
