Author: Subject: diff back plate
locoboy
posted on 10/3/05 at 09:31 PM Reply With Quote
diff back plate
Chaps,
i know the 7.5 diff is 7.5 inches across the mounting bolt area and 7 inch is 7 inches, i also know that the 7 and 7.5 inches relates to the crown wheel size too,
but do they share the same sized back plate?
Locoboy
Stu16v
posted on 10/3/05 at 09:58 PM Reply With Quote
No mate here, thrid pic down (I think)...
Cheers, Stu.
locoboy
posted on 11/3/05 at 10:14 AM Reply With Quote
balls!
Looks like i will have a spanking new 7 inch back plate taking up space in my shed then
Locoboy
Stu16v
posted on 11/3/05 at 07:22 PM Reply With Quote
This *might* be a bit of luck (for me, anyway...) How much do you want for it mate?
locoboy
posted on 13/3/05 at 05:23 PM Reply With Quote
Stu,
On second thoughts i may need it.
I want to get a 3.38 diff and use my 3.62 LSD to cobble together a 3.38 LSD set up.
Now is it best to put the LSD bits into the 7 inch 3.38 diff housing
or
put the 3.38 bits into the 7.5 inch 3.62 LSD housing?
Locoboy
posted on 13/3/05 at 05:46 PM Reply With Quote
the usual approach seems to be to put the LSD into the new ratio, to avoid having to re shim the cogs. But you would obviously need to make sure that the 7" and 7.5" lsd internals are compatible.
NS Dev
posted on 14/3/05 at 08:42 AM Reply With Quote
I don't know about the cross-compatibility on this one, but the 7" diff ratio os 3.62:1 and the cosworth 7.5" is actually 3.64:1, pedantic but I don't know what this might infer about differences between internals, apart from obvious incompatibility of the crownwheel and pinions between the two.
locoboy
posted on 14/3/05 at 09:32 AM Reply With Quote
Bollocks is there anyone i can contact directly that can give me a definative answer?
I need to know what im going to do - im having a rerar end quandry (oooooerrrrrr)
Got Drum uprights and drum brakes and shafts, Lobro 7.5 inch cosworth LSD with a cracked back plate and a brand new 7 inch backplate
Can anyone come up with a plan out of all that!
i would ideally like disk brakes though ;-)
Locoboy
NS Dev
posted on 14/3/05 at 01:03 PM Reply With Quote
sell what you have and buy an XR4x4 backend complete, £50 max!
Stu16v
posted on 14/3/05 at 07:19 PM Reply With Quote
The 3.38 bits will not fit in the 7.5 housing - or rather, they *might* fit, but the gears will not be meshing...
It might be possible that the 'LSD bit' of the 7.5 inch will fit into a 7 inch case (I doubt there is any extra width, as Sierra driveshafts are the same length IIRC).
It just happens that I have a 7" LSD which I have taken out of my car, as it was rather noisy. It might just be the CWP worn - any use?
Cheers, Stu.
posted on 14/3/05 at 07:26 PM Reply With Quote
you find them, i'll buy 'em!
locoboy
posted on 15/3/05 at 09:09 AM Reply With Quote
Stu,
Think i need to have a chat to you about this over a beer in the near future
You have U2U
Locoboy
