RICK1
| posted on 18/3/05 at 05:49 PM |
avo shocks
ive just taken delivery of my avo coil overs and just noticed the shocker bush hole is smaller than hole in wishbones+ chassis any 1 else had this
bother? bolt listed 4 build is 2 big 2 go through bush sleeve.
MikeR
| posted on 18/3/05 at 06:23 PM |
phone avo, tell them the size of bush you need and they will hum and arrr a bit. Then they will find that the mini bush will fit and send you some of
those. The only problem with the mini bush is its about 4mm smaller in length.
its what i did.
