Author: Subject: Pedal box
Danozeman
posted on 20/3/05 at 10:12 AM Reply With Quote
Pedal box
Has anyone got any pics of the gts tandem cylinder pedal box? Theres not one on the site.
Wheres the best place to get one from. I want/need floor mounted.
Dan
MikeR
posted on 20/3/05 at 06:17 PM Reply With Quote
I keep thinking the same every time i have another problem with my top mounted (well its usually the same 2 problems, the clutch and the accelerator pedal.)
I've been looking at the stuart taylor ones, they do look rather nice although the clutch cable has to go through the bottom tube so cutting a hole and welding a tube for it to go through needs to be done (well it doesn't need to be done but i would want to).
MK does some, i've not seen them not in a car.
The last time I talked to darren he didn't do a complete pedal box, but does all the bits to make a pedal box bar the mounting brackets (this was a while ago and he was looking at making a complete solution)
clbarclay
posted on 20/3/05 at 09:40 PM Reply With Quote
The MK floor pedals have the cables mounted at an angle so that they clear the top of the chasssis rail.
Danozeman
posted on 21/3/05 at 06:41 PM Reply With Quote
I was going to use the un modified escort one but its not gong to happen. the luego one seems tad pricey.. hadent thought of MK.
Dan
