Danozeman
posted on 20/3/05 at 01:27 PM |
Oh dear..
Boll*x ive just made myself more work!
Image deleted by owner
I was having such a good morning annoying my neighbours with my grinder taking the brackets off my axle. Then i did this. A light tap on the
handbrake bracket and it did this. Had no idea it was this thin!! Nothing that cant be solved when i weld my brackets on..
Dan
RogerM
posted on 20/3/05 at 02:20 PM |
They do that alot. Rust to bits those back plates!
If it's that thin there it's probably not much better all over! Some of the Ford specialists will be able to sell you a replacement back
plate to weld in, failing that you can us a good second hand one from something like a bent axle.
I wasted many hours a few years ago trying to repair one .... just no solid metal to weld to at all.
RoadkillUK
posted on 20/3/05 at 05:15 PM |
We did the same thing with ours
Cleaned it up and then welded a plate over it.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
Danozeman
posted on 21/3/05 at 06:38 PM |
Im so glad im not the only one!! Thought id been a bit of a tit. I was going to plate it tonight but ive run out of gas so i cant. It is very thin
so i dont think ill be able to but im gonna have ago.
Dan
RoadkillUK
posted on 21/3/05 at 10:13 PM |
Hey, just 'cos someone else has done it doesn't mean you're not a tit
Best of luck (I had to weld it 3 times 'til it stopped leaking)
Roadkill - Lee
www.bradford7.co.uk
jonbeedle
posted on 22/3/05 at 02:36 AM |
I've got a Mk2 Escort axle casing you can have. I'm in Lakenheath Suffolk.
Jon
Danozeman
posted on 22/3/05 at 02:56 PM |
I am a tit..
Dan
James
posted on 22/3/05 at 04:19 PM |
If you cleaned it up well you could braze a new piece on. Would be so hot and risk blowing holes then!
HTH,
James
- Muhammad Ali
Danozeman
posted on 22/3/05 at 04:55 PM |
Ive just mig'd a plate on it which has sealed it up nicely.. But i think my diff bearings are screwed so it may be a new axle..
Dan
