Author: Subject: front hubs help needed please !
GazzaP
posted on 22/3/05 at 03:49 PM Reply With Quote
Hi
I have a locost which i am racing i have found out this week that my calipers are shot so i bought some re-con sierra items which do not fit my hubs.
the question is how can i get these to fit i think i have the wrong hubs on the car which ones will i need and where can i get them from.
thanks in advance
Gary.
flak monkey
posted on 22/3/05 at 03:53 PM Reply With Quote
Stupid question but I assume you do have Sierra uprights...? How do they not fit? (pics?) Bolt spacing on the upright or something else (disk thickness)
Sera
http://www.motosera.com
GazzaP
posted on 22/3/05 at 04:03 PM Reply With Quote
I think that is the problem the uprights look like they are westfiled alloy items and not sierra ones that i need any ideas of where i can get some and will sierra calipers bolt on to cortina uprights.
also do the new uprights need to machined to be able to fit the cycle wings?
sorry for the lack of info and thanks for the help
Gary
flak monkey
posted on 22/3/05 at 04:12 PM Reply With Quote
AFAIK the westfield alloy uprights are based on cortina geometry.
Sierra calipers wont bolt onto Cortina uprights.
You can get new standard cortina calipers from
www.brakesint.com
And there are many companies selling wilwood (or other alloy) calpiers with cortina fitment.
The cortina calipers are M16.
Sera
James
posted on 22/3/05 at 04:18 PM Reply With Quote
Gazza,
Looking at your website, are you competing in the Locost racing series? If you are then I'm surprised you can use alloy uprights! Even more surprised you bought Sierra calipers!
James
GazzaP
posted on 22/3/05 at 04:32 PM Reply With Quote
It's ok as i got the sierra calipers foc so thats not a problem the hubs on the car have had the thread stripped out of the mounting bracket so i need new uprights and hubs do the cortina uprights have the mountigs for the wing bracket.
thanks
Gary
flak monkey
posted on 22/3/05 at 04:44 PM Reply With Quote
Most people use the mounting points for the 'splash' sheild to mount there cycle wing brackets since you remove the splash sheild anyway.
Good luck finding some Cortina uprights at a reasonable price.... I just managed to get some from a mate on the cheap....(before you suggest banger drivers (as i do) many are wise to the kit car market and are selling them to kit manufacturers for a tidy sum, so are recluctant to part with them sometimes)
Sera
Stu16v
posted on 22/3/05 at 08:38 PM Reply With Quote
Gazza, you have U2U...
RazMan
posted on 22/3/05 at 09:39 PM Reply With Quote
Gazza, I might have a pair of nearly new Wilwood Dynalites (complete with Cortina adaptors) going begging if you decide to go that route. I've also got one Cortina hub too.
[Edited on 22-3-05 by RazMan]
Raz
Kissy
posted on 23/3/05 at 01:28 PM Reply With Quote
And how much would the n/new Wilwoods be begging for? I'm v.Interested by the way!
DarrenW
posted on 23/3/05 at 02:00 PM Reply With Quote
Gazza,
There are 2 different calipers fitted to the run of the mill Sierra - girling and teves.
Do you have the old calipers - i assume they are different to the new ones, maybe this is the reason. I would take th enew calipers back and also take the knackered ones along - maybe you can identify them out of a catalogue.
posted on 23/3/05 at 05:44 PM Reply With Quote
Get the old upright helicoiled --- should be stronger than original. Altenative drill and tap for larger bolt.
