Author: Subject: Driveshaft
A fulton
posted on 26/3/05 at 03:13 PM Reply With Quote
Driveshaft
Hi all
Can you help just put my diff and shaft in a viento 7" diff Lift the rear suspension up and down and the o/s shaft is pulled out
Liam
posted on 26/3/05 at 03:15 PM Reply With Quote
You got the shafts the wrong way round?
A fulton
posted on 26/3/05 at 03:28 PM Reply With Quote
DRIVEshaft
NO put the long one in the o/s
NS Dev
posted on 26/3/05 at 03:54 PM Reply With Quote
It shouldn't be able to pull out really, if the circlips are fitted!
I know that the circlips aren't supposed to be under load as such, but if both the CV's are at the outer limits of their travel then the shaft may be able to drop out between them.
Liam
posted on 26/3/05 at 05:50 PM Reply With Quote
More information might help - like what kind of shafts are they, how much they 'pull out', photos even...
liam
Avoneer
posted on 26/3/05 at 06:13 PM Reply With Quote
If you have push in shafts - they don't lock in or anything, just sit there nicely.
Is the shock fitted?
'Cause I'm sure if you push the shaft up, it will pop out if nothing is stopping it going beyond "normal" use.
Is everything bolted together eg, rear bones and rear upright as these all hold the shaft in position.
Pat...
A fulton
posted on 27/3/05 at 08:09 AM Reply With Quote
Shafts
HI
No circlips on standerd Sierra shafts
Shafts pull out 10mm went shaft is level
and everything is bolted up
standerd sierra shafts with 7" ditf
theconrodkid
posted on 27/3/05 at 08:28 AM Reply With Quote
have you taken CV,s apart?there is a spring in there to push joints apart,maybe spring missing/broken?
who cares who wins
pass the pork pies
Liam
posted on 27/3/05 at 12:52 PM Reply With Quote
Yeah - definately sounds like the springing on your shaft is dodgy.
liam
A fulton
posted on 27/3/05 at 01:32 PM Reply With Quote
Driveshafts
HI, sorry the shafts are new ones
iv,e tryed the spring in the CV,s OK
NS Dev
posted on 27/3/05 at 07:17 PM Reply With Quote
I thought all 7" diff sierras had lobro shafts with 6 bolt flanges. Surely all the pull-out shaft ones are 6.5" diffs!!!
Liam
posted on 27/3/05 at 07:33 PM Reply With Quote
Huh?? All the sierra diffs are 7" (apart from cossie of course). Oh and 4x4 front diffs are 6.5". Maybe there was a really early 6.5 or something, but us locosters are all using 7s, either push-in or flanged - the diffs are identical.
Really can'twork out mr fulton's problem. Detailed photos might help.
Liam
Stu16v
posted on 27/3/05 at 08:50 PM Reply With Quote
Are you moving the suspension through the same amount as the shocker would allow? Any more, and it might just pop out...
NS Dev
posted on 28/3/05 at 09:49 AM Reply With Quote
[Edited on 28/3/05 by NS Dev]
A fulton
posted on 28/3/05 at 04:09 PM Reply With Quote
DRiveshafts
Hi all
Have put spacers on the n/s of the diff to off set to the o/s a pit . And the shaft only come,s out 5mm is this OK can not move more or it start on the N/S
