Hornet
posted on 28/3/05 at 08:27 AM |
GTS Dampers/coils
Guys.. How do you know how far you screw the "C" spacer on the Dampers. I'm guessing you adjust these to try and have an even
weight distribution on your 4 corners?
Any help appreciated.
Triton
posted on 28/3/05 at 09:06 AM |
yep thats right as well as adjusting the ride height.
posted on 28/3/05 at 09:41 AM |
You have to know the total weight, the front-rear weight distribution and the left-right wight distribution then you can work out the correct corner
weights for each corner .
