Author: Subject: English axle / irs
kabaman
posted on 11/11/02 at 11:13 AM Reply With Quote
English axle / irs
I have a Ford Anglia 105e with a 2.9i engine and 4 speed. I have never managed to get an english axle with lower gearing and LSD for a decent price. Can anyone tell me anything about a cossie siera back end. Do these have LSD's? do they mount on a beam? What is their track? If anyone has any suggestions on a likely IRS with LSD replacement can they please tell me about it.
Neil
chrisg
posted on 11/11/02 at 06:41 PM Reply With Quote
The Cossies are independant suspension and maybe difficult to fit without big mods, you really need a live axle- the only one I can think of which has a LSD is the 2.8 capri, which maybe too wide or a special(Quaife?)MK2 escort, these wont be cheap tho...
HTH
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
Cousin Cleotis
posted on 11/11/02 at 07:17 PM Reply With Quote
www.raldes.co.uk sell LSD kits and crownwheel and pinions as low as 3.3:1 for mk 1 and 2 escorts
bob
posted on 11/11/02 at 08:18 PM Reply With Quote
Vauxhall Senator and Opel Monza did a LSD and are live axle
interestedparty
posted on 11/11/02 at 08:26 PM Reply With Quote
Sounds like your problem it the 4speed gearbox, the highest ratio of which will be 1:1. What you need is a 5speed gearbox which will have 5th gear in the region .8 (as are most Ford 5speeds). You will then have a much wider choice of suitable axles
John
johnston
posted on 11/11/02 at 11:30 PM Reply With Quote
or!!!!!
a mate of mine cut the axle tubes off a atlas axle used the inner cv joints from a golf and welded the splines from the half shaft on
(he used vr6 shafts but was usin hubs and struts as well)
make up wishbones and shafts use fwd uprights and struts
and viola irs on the cheap and works well 2
