planetester
| posted on 31/3/05 at 04:40 PM |
Handbrake
I'm trying to set up the allegro handbrake cables to my escort backplate, Ive no coilovers yet but when I jack up the chassis to let the axle
rest on it the cables are at quite an angle to the back plate levers, does the chassis act as the limit of travel for the axle or do the coil overs
reach full extension by then, if so what clearance have you got between your axle & chassis at full extension, I plan to use GTS coil overs
thanks
Deckman001
| posted on 31/3/05 at 06:22 PM |
I fitted my handbrake cables last weekend, these also look very odd but they can't be at any other angle really, mine will be better when the
car is at normal ride height as this will move the axle away from the lowest possition and it won't 'look' so bad as there
won't be anything close to compare it to
Jason
DavidM
| posted on 1/4/05 at 12:00 AM |
Mine came out like this. It took a bit of trial and error to get bracket above the chassis and the cable to pull reasonably straight.
Proportion is Everything
