Author: Subject: Stupid question
shortie
posted on 1/4/05 at 10:02 PM Reply With Quote
Stupid question
This may be a silly question but am I right in assuming that if I wind the spring platforms up it will lower the ride height?
Rich.
tri
posted on 1/4/05 at 10:07 PM Reply With Quote
yeah your right but it would make it harder thats what my dad thinks
i think it would raise it and make it harder
[Edited on 1/4/05 by tri]
ady8077
posted on 1/4/05 at 10:13 PM Reply With Quote
Wont it raise the ride height?
As your making the distance between the wisbone and chassis bigger
It wont make the suspension harder as it shouldn't compress the spring just open up the shock
Adrian
Mr G
posted on 1/4/05 at 10:18 PM Reply With Quote
Winding them liiterally 'UP' as in upwards will raise the ride height.
G
smart51
posted on 2/4/05 at 11:04 AM Reply With Quote
It won't make the springs stiffer. Springs are linear across their working range. It will preload the springs a bit more. This means you'll have to put more weight on them before they start to compress but they will still compress at the same N/mm rate.
