Author: Subject: Brake calliper cleaning
Jumpy Guy
posted on 6/4/05 at 03:07 PM Reply With Quote
Whats the best stuff to clean the outside of brake callipers?
ive tried a search and cant find anything!
flak monkey
posted on 6/4/05 at 03:10 PM Reply With Quote
To get rid of the dust? And are they attached to anything? If not give them a bath in meths (shouldnt hurt the seals). If they are attached to the upright use a stiff brush and really soapy water.
Sera
http://www.motosera.com
tom_loughlin
posted on 6/4/05 at 03:19 PM Reply With Quote
if you mean rust, i used the electrolysis technique (which is great) - nothing stuck, and i didnt seal anything and they still worked fine after nearly a year! - then painted them in a high heat spray - which is crap and flaking off already. in the winter, ill strip them and pain them in propr calliper enamel.
Tom
Jumpy Guy
posted on 6/4/05 at 03:20 PM Reply With Quote
they're off, but covered in muck and dust..
so meths is best?
JonBowden
posted on 6/4/05 at 03:25 PM Reply With Quote
Most general parts shops sell brake cleaner spray. I got a can free with the brake disks I bought a while ago
Jon
flak monkey
posted on 6/4/05 at 03:27 PM Reply With Quote
Give em a wash first in plain old soapy water, then meths if they need it. You should find all the crap will come off fairly easily... Make sure you dry them out properly before fitting them though!....
Washing them in petrol is also a possibility i guess
Sera
posted on 6/4/05 at 03:31 PM Reply With Quote
I used the Granville Brake Cleaner spray. Shifts most greasy & oily deposits, and safe for use inside brake components. Not expensive, and has lasted for ages.
Splendid for degreasing small parts as well - but watch out for the fumes! You'll be seeing all sorts of strange creatures if you use this stuff in a closed space.
(oh look - a furry pink elephant is flying round the light fitting...)
grusks
posted on 6/4/05 at 06:38 PM Reply With Quote
Mr musle oven cleaner, the can type. Comes out in a foam. Work the muts nuts.
Good on ali wheels as well
Need More Money
