Author: Subject: Steel suitable for Suspention.
DorsetStrider
posted on 8/4/05 at 02:07 PM Reply With Quote
Ok peeps, time to pick your brains again.
What tubing is suitable for the suspension? Do you HAVE to use seamless or can you step up wall thickness and use seamed instead?
What other things can you use?
Who the f**K tightened this up!
posted on 8/4/05 at 05:43 PM Reply With Quote
many people have used seamed tubing for their wishbones and got away with it happily as ive said before, ive driven on 19mm 16g square erw before, it never collapsed. Planned upgrade to 25x2mm round tube if i can be arsed.
RogerM
posted on 8/4/05 at 05:53 PM Reply With Quote
I got away with 16g 25mm ERW for ages, until I hit a curb hard at Castle Combe ...
The trick is to make sure that you weld the plate to the CENTRE-LINE of the tube and that the tube is arranged so that that weld runs along the original joint seem so it is a redundent feature.
Upgrading to 25mm x 2mm CDS for the load bearing arms. In my suspension design that is both upper and lower front wishbones and lower rear wishbones.
Due to the shock arrangement I can make do with ERW (25x2 though to be sure) for the upper rear wishbones
I would recomend CDS. It's not too much more expensive and a better engineering solution. 1 length should be enough to do all of a live axle car.
DorsetStrider
posted on 9/4/05 at 12:25 AM Reply With Quote
So would 25mmx25mm square steel tubing with a wall thickness of 3mm be strong enough then? Or am I still going to be hunting for a local supplier of round steel tubing?
Mix
posted on 9/4/05 at 07:28 AM Reply With Quote
I'd be happy enough to use 25x25 x3 for wishbones.
I would confirm first that there would be no issues with the SVA concerning the radius rules.
Mick
jolson
posted on 9/4/05 at 08:45 AM Reply With Quote
Does anyone know the size/wall thickness of the oval tubing that MK uses for their lovely wishbones? I'd have a set myself, but I'm messing with the front geometry (wide track, etc) and I doubt they would fit.
John
DorsetStrider
posted on 9/4/05 at 01:20 PM Reply With Quote
I don't think there would be any SVA issues as my wishbones would be inboard like on a production car.
