jestre
posted on 12/4/05 at 07:31 PM |
RX-7 Lower control arm useable?
Thinking of buying these arms, will they fit the Mcsorely +442 chassis?
jestre
posted on 12/4/05 at 07:32 PM |
These are from a 2nd gen.
I will need some custom mounts of course.....
[Edited on 12/4/05 by jestre]
clbarclay
posted on 12/4/05 at 07:51 PM |
Is that intended for use in place of the front lower wishbones?
jestre
posted on 12/4/05 at 08:00 PM |
yes.... I have 1st gen RX7 hubs/spindles that should attach directly to these arms.
posted on 13/4/05 at 12:46 PM |
Where does the spring and damper mount on the RX7? It it's not on the bottom arm, then it's probably not suitable.
ned
posted on 13/4/05 at 12:54 PM |
and the length of the arms? are they going to give you the right track and geometry, steering? or will you have to completely modify the front end to
get the pickup points in the right places?
Ned.
beware, I've got yellow skin
