JohnLocost7
| posted on 17/11/02 at 07:02 PM |
Gearchange extensions
If you running a Ford 5 speed Type 9 gearbox and you hand hits the dash every time you change gear I've found the something that may help.
WWW.Extension by David Jenkins.
[Edited on 19/11/02 by JohnLocost7]
| posted on 18/11/02 at 09:00 AM |
Well, you only had to ask...
Seriously though, it does work a treat (although it hasn't been run in anger yet).
P.S. It's polite to name the author of a design...
[Edited on 18/11/02 by David Jenkins]
zetec
| posted on 18/11/02 at 09:23 AM |
Even easier use a MT75 'box. Just cut the gear linkage and craddle, lengthen it with some tube and weld up and you can put the gearlever just where
you want, easy.
Liam
| posted on 18/11/02 at 02:09 PM |
Or put the engine and box far enough back you don't have to bother at all
Liam
JohnLocost7
posted on 19/11/02 at 12:13 AM |
The engine and box far back as they can go.
I need it because I'm 6 4 and have harness so I can't strech to get it also my hand would hit the dash.
I'll put a pic up later.
JohnLocost7
| posted on 19/11/02 at 07:42 PM |
Some Pic's of the PROBLEM
JohnLocost7
| posted on 19/11/02 at 07:43 PM |
and another
JohnLocost7
| posted on 19/11/02 at 07:44 PM |
last one.
