Author: Subject: old post about Banjos
saigonij
posted on 26/4/05 at 06:55 PM Reply With Quote
Been reading this old post and was worried when i got to the third thread down...
http://www.locostbuilders.co.uk/viewthread.php?tid=25342
it talks about proving to the SVA man that the caliper inleet holes are not tappered.
does this still cause a problem?
Snuggs
posted on 27/4/05 at 07:07 AM Reply With Quote
My SVA tester insisted that I prove that the hole in the caliper was not tapered.
Original sierra hoses are not taper fit so I either had to disconnect them at the SVA station (and then re-bleed the brakes ) or take photos at home.
I also took the old sierra flexi ends with me.
Some sierra calipers are not machined around the hole (especially the rears) but need to be to get a good seal.
Fronts were OK but I just carefully filed the rears.
I will put some photos in my archive
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
Dick Axtell
posted on 27/4/05 at 09:31 AM Reply With Quote
Hydraulic Inlet Ports
WTF was all that about???
Car/Light vehicles brake equipment has Europe-wide standardised inlet port form, using M10 x 1 parallel thread.
As an SVA tester, he shoulalready know this - shouldn't he??
NB - Older Eastern-bloc sourced cars e.g. Lada, had brakes which used M10 x 1.25 threads. Typical!!
