Author: Subject: petrol tank float
alfasudsprint
posted on 28/4/05 at 09:52 PM Reply With Quote
petrol tank float
Have decided to buy a new tank float and sender as they are about 15 UKP here, any suggestions on what to look for?
planetester
posted on 28/4/05 at 10:27 PM Reply With Quote
If yo have an existing one that matches you gauge, you need to measure the resistance in ohms, both full & empty, get one that matches, If you dont have one already, you will have to experiment with different value resistors to see what you need for full & empty
tks
posted on 29/4/05 at 07:18 AM Reply With Quote
get a pair of adjustable resistors
and when you face
the problem that the resistance have to be lower, then connect them in paralell.
That should do the trick..
TKS
