Author: Subject: traillers !
ayoungman
posted on 4/5/05 at 07:56 AM Reply With Quote
traillers !
Sorry, a bit off topic but here goes.!
I've got a two axle trailler with a load capacity of 3 tonnes. It has mini based hubs on at the moment. I want to increase ground clearance by fitting bigger diameter wheels. Whats the best solution, since mini wheels are only small. Can I swop the hubs to a different type. What will fit ?
Help, any ideas ?
"just like that !"
mangogrooveworkshop
posted on 4/5/05 at 08:51 AM Reply With Quote
Heres Johnny
Try www.autow.co.uk they have the wheels and hubs at a good price and free p&p
flak monkey
posted on 4/5/05 at 08:52 AM Reply With Quote
Can you just get bigger wheels with the same PCD? If so you could fit those, and fit quite high profile tyres to increase the ground clearance.
Most trailers use mini wheels, but some use larger ones, im not sure if they fit the same hubs or different ones. May be worth asking at your local trailer place?
{Beaten to it!! }
[Edited on 4/5/05 by flak monkey]
Sera
http://www.motosera.com
clbarclay
posted on 4/5/05 at 09:06 AM Reply With Quote
Ford Transit (or other similare size vans) should yeild complete beam axles and even leaf springs that are ideal for home made trailers.
posted on 4/5/05 at 10:37 AM Reply With Quote
12" early metro wheels or some caravan wheels will fit mini centres.
ayoungman
posted on 4/5/05 at 11:55 AM Reply With Quote
cheers lads !. Have located landrover axles and wheels. Should be strong enough !!!!!!!!!
"just like that !"
