Danozeman
posted on 16/5/05 at 02:53 PM |
panhard rod..
Another question from me.... You people must love me...
Im after a panhard rod with a rod end one end as i think this will be better than the normal.. Wheres good to get one from.. I see the GTS is
17.50 plus 12.50 for the rod end.. Is this good.. It seems resonable to me..
Dan
NS Dev
posted on 16/5/05 at 03:09 PM |
It's as good as you'll get I would say.
Certainly I wouldn't make one for any less, not worth the hassle.
lewis635
posted on 16/5/05 at 03:30 PM |
Marc nordon do a rose jointed panhard rod for £14, not sure if that includes rose joints probably not at that price but he sells 1/2" rose
joints for £9. here's the link
MNR Panhard Rod
I am just about to buy one
[Edited on 16/5/05 by lewis635]
clbarclay
posted on 16/5/05 at 03:49 PM |
They are not to hard to DIY, thats what i did with mine. I would say there probably easier to make than panhard rod with bushes at each end.
I suspect MNR panhard rod uses rose joints at both ends given the way its worded.
[Edited on 16/5/05 by clbarclay]
Danozeman
posted on 16/5/05 at 04:36 PM |
It sure sounds like the mnr one comes with rose joints... Il email or ring him and find out..
For the sake of 20 quid it hardly worth making one.
Dan
clbarclay
posted on 16/5/05 at 06:00 PM |
If a MNR rose joint costs £9, then a pair will come to more than £14. £32 sounds more likely, still not a lot mind. Best bet is to ring them up and
get a price straight from them.
Danozeman
posted on 16/5/05 at 07:34 PM |
i thought about that after id posted that clbarclay. A tad slow today after a lack of sleep... Iv emailed them to see.
Dan
Danozeman
posted on 18/5/05 at 03:19 PM |
22 quid all in with bush and rose joint..
Dan
posted on 18/5/05 at 04:55 PM |
An easy way to make one for a 1/2" UNF rose joint is to cut off the threaded end of a Mini/Viva/Avenger/Marina track rod end turn it down a bit
and braze into the end of the panhard rod tube.
Best brazed not welded as track rod end are made of a high tensile "EN" steel and I am not sure how strong a weld would result.
Mark Allanson
posted on 18/5/05 at 08:39 PM |
..or just extend a Nissan Bluebird rear radius arm, and use the unmodified ones as trailing arms
