Findlay234
| posted on 11/12/02 at 08:56 AM |
wheel PCD
does cortina have same PCD (pitch circle diameter) as sierra. ie can i use the same wheels?
jollygreengiant
| posted on 11/12/02 at 11:35 AM |
I believe the answer is yes but the sierra uses bigger diameter studs & nuts and I think that the centre hub spigot mount is also slightly larger.
johnston
| posted on 11/12/02 at 05:54 PM |
i've also been told that the offset on the sierra is actually a fwd one but the guy could ave meant 4wd ones
not sure mesel but mayb somethin to check
