andylancaster3000
| posted on 20/6/05 at 03:38 PM |
Cortina Uprights Dimensions
Has anyone got the dimensions of the cortina upright?
I have been thinking about fabricating some after seeing some of the things Rorty has posted on here and due to the rapidly drying up stocks of
uprights!
Thanks,
flak monkey
| posted on 20/6/05 at 03:40 PM |
I have this which came from somewhere I cant remember!
Should give you enough to get the critcal dimensions.
Sera
http://www.motosera.com
andylancaster3000
| posted on 20/6/05 at 03:54 PM |
Thats great, exactly what I was looking for!
Some strange angle's on there! I didn't realise the joint lugs pointed in all directions like that! Is there any reason for that? From how
I see it, aslong as they are offset the correct amount from each other (when viewed from the front) they don't need those strange angles. I can
understand it on the top lug, to match the andle of the top 'bone but not the bottom one or the track rod lug.
Any views on this?
[Edited on 20/6/05 by andylancaster3000]
andylancaster3000
| posted on 20/6/05 at 04:03 PM |
Sorry, completely ignore what i just said!!
There can only be one rotational axis so they can'y be offset without them inline with each other!!!!
ned
| posted on 20/6/05 at 04:12 PM |
i saw a cortina (or possibly granada) banger/stock car on the back of a lorry at thurrock services on the way back from snet on sunday, they do still
exist
beware, I've got yellow skin
andylancaster3000
| posted on 20/6/05 at 04:30 PM |
What a waste...They're probably bent to b******y now though
flak monkey
| posted on 20/6/05 at 04:49 PM |
I know several people who regularly banger race cortinas, Mk3-5, and also some older stuff in pre 60's!
I got a pair of uprights off a Mk3 banger, only thing bent seems to be the splash shields which i dont need anyway!
There are still plenty of Cortinas around, its just a case of beating the BR boys to them
Sera
andylancaster3000
| posted on 20/6/05 at 05:08 PM |
Hmm.. I'm having great trouble getting them. Having said that, I havn't looked much further than Ebay. They seem a little expensive on
there. Any ideas of where to start?
flak monkey
| posted on 20/6/05 at 06:49 PM |
Your local banger track would be a good place, if you want to go that route. Talk to a few of the drivers, you will find they will know what cars
other drivers have lined up.
Or you could give tiger racing a call, they can usually supply a pair off a donor for a bit of cash. (most of theirs come from the local banger boys
Sera
