Author: Subject: Suspension Bolts etc.
The Doc
posted on 24/6/05 at 08:09 PM Reply With Quote
Hi folks,
Some basic questions about suspension bolts. Firstly are 8.8 high tensile enough? Should we be putting a washer under both bolt head and nut, just one or the other - or does it matter at all! (nylocks assumed). Thirdly - is it ok for the bolt to pull up flush with the end of the nut, or does the SVA man like to see a few threads protruding?
Mike
shortie
posted on 24/6/05 at 08:28 PM Reply With Quote
8.8 is fine, yes, washer both ends, nylocs and at least 2 threads showing
HTH,
Rich.
jambojeef
posted on 24/6/05 at 09:06 PM Reply With Quote
Hi there,
I would ask what diameter of bolk shank you are planning to use and on what part of the suspension.
For example my front lower wishbone arms to chassis bolts are "only" M8 8.8 at the minute but the top are 1/2" UNF 8.8.
Having read posts on the subject I am of the opinoin that M8 8.8 at that part of the suspension only leaves a relatively small safety margin compared to the rest of the suspension fasteners and so I plan to change these to 12.9 capheads before SVA.
I have used a washer both ends and nylocs as Shortie has.
Interesting to note that 2 threads should be showing Rich - is that an SVA requirement?
Geoff
shortie
posted on 24/6/05 at 09:09 PM Reply With Quote
I know that there has to be sufficient showing for SVA, I belive from others that it is 2 threads at least but it is standard practice not just for SVA.
HTH,
Rich.
smart51
posted on 24/6/05 at 09:13 PM Reply With Quote
Does the 2 thread rule apply to nylocks only or do you have to do this with normal nuts as well?
Mark Allanson
posted on 24/6/05 at 10:08 PM Reply With Quote
How does the nut know how many threads are showing?
Just physical fasteners that use the end of the nut to lock ie castle/nylok/split/truncated etc etc
posted on 25/6/05 at 07:53 AM Reply With Quote
A nyloc actually becomes a "self-slackening" nut if the nyon insert isn't fully on a parallel part of the thread
The Doc
posted on 25/6/05 at 11:57 AM Reply With Quote
Thanks for that folks,
I've gone the standard 'book' suspension bush route where the bolts are more like M9 but are actually UNF. Anything else is sloppy or wont go in.
I have now taken all the F****n wishbone bolts out and put slightly longer bolts in. What a pain the the arse, but better now than after completion I keep telling myself!
PS Anyone know where I can get hold of one of those 90 degree speedo cable outputs for the crossflow gearbox
Jeffers_S13
posted on 27/6/05 at 10:52 AM Reply With Quote
I noticed the top front wishbone ball joint thread isnt long enough on my car, the thread *just* gets flush with the end of the castle nut under the top part of the upright, can you get ball joints with a longer threaded section ??? see pic in archive for better description of what I mean...
[Edited on 27/6/05 by Jeffers_S13]
posted on 27/6/05 at 11:55 AM Reply With Quote
Same problem on mine. I think the standard fix is to have the taper in the upright reamed out a bit more.
Jeffers_S13
posted on 27/6/05 at 12:03 PM Reply With Quote
Surely not ? thats gonna be a right chew on at this stage of my build. I only just noticed it as I was fitting the calipers.
Rorty
posted on 28/6/05 at 05:51 AM Reply With Quote
Originally posted by jambojeef
...my front lower wishbone arms to chassis bolts are "only" M8 8.8 at the minute but the top are 1/2" UNF 8.8.
There is no such thing as a "1/2" UNF 8.8" fastener. You're confusing two entirely different and non-interchangeable thread systems.
Class 8.8 fasteners are indeed metric, but your "1/2" fasteners are imperial and graded, not classed. The nearest imperial equivalent of a Class 8.8 bolt would be a Grade 5 item.
At 150 PSI, a SAE Grade 8 is almost equivalent to the metric Class 10.9 (1034 MPa) and a Class 12.9 fastener comes in at 1200MPa.
So, if you are actually planning on using Class 12.9 bolts for the wishbones, then I assume they'll be M6 (6mm diameter)?
As most of the wishbone fittings will be designed for imperial fasteners, then 1/2" Grade 8 fasteners will be more than man enough for the job. If you were pinching weight for racing, then you could even step down a size to 3/8" Grade 8 bolts, though you'd obviously have to make new cruch tubes for the wishbone bushes.
As a rule, a washer is not necessary under the head of a bolt, unless the fillet between the head and shank of the bolt will interfere with the edges of the hole. I usually just countersink the edges of the holes where there is insufficient clearance, though in reality, if you follow the standards for bolt/hole tolerances, then you'll not have to worry about it. If you are required to fit a washer, make sure it too either has clearance for the fillet or is countersunk/radiused. I only use militry ground, hardened and radiused washers.
A washer should be fitted under all nuts, no matter what their style or material. For anything mechanical or critical, purchase, as a minimum, hardened washers. The plain mild steel ones that you can buy at every hardware shop are just OK for resillient components, but are too soft for bolting against aluminium. If using the stamped variety of washer, place the top (rounded) side against whatever is being bolted and not the nut.
Cheers, Rorty.
posted on 28/6/05 at 07:10 AM Reply With Quote
Just remember folks, when getting technical about suspension bolt types and strengths, that the bolt is held by a strip of mild steel just 3mm or 1/8" thick.
I would suspect that the suspension brackets would give way a long time before the bolt even got bent.
Just my 2p's worth...
The Doc
posted on 28/6/05 at 07:31 AM Reply With Quote
Ball Joint Threads
Jeffers,
I see that you have washers (quite thick ones at that) under your ball joint nuts. The Cortina manual shows no washers. Drop these and you might get the clearance you're after. (pic attached) Rescued attachment MVC-001E.JPG
Jeffers_S13
posted on 28/6/05 at 09:43 AM Reply With Quote
Aha ! good spot ! will try this
James
jambojeef
posted on 29/6/05 at 09:09 AM Reply With Quote
Hi Rorty,
Thanks for keeping me right there buddy - I meant "equivalent 8.8 1/2" UNF"
I think its grade R IIRC
cheers
Geoff
