Author: Subject: Axle weight
unixguy
posted on 22/7/05 at 03:24 PM Reply With Quote
Axle weight
Can anyone tell me the approximate weight of a Ford Sierra rear axle, and that of a Ford MKI/II Escort? Thank you :]
NS Dev
posted on 24/7/05 at 07:54 AM Reply With Quote
totally different setups as the sierra is independent suspension and the escort is live axle.
If you mean the entire rear axle setup on the sierra (which you are unlikely to use all of on most 7's) then it is a LOT heavier than an escort axle!
