unixguy
posted on 23/7/05 at 03:22 PM |
Which axle for BEC
I'm using a Fireblade in my car [Locost ish, which will be used as a road car only]. What are your opinions as to the axle/diff best to use with
this engine?
posted on 23/7/05 at 03:52 PM |
Depends whether you want LSD or not. If you're not particularly bothered, go for a 3.38:1 open diff. Otherwise a 3.62:1 Limited slip diff from
an XR4x4.
Oops, just seen you're building a Locost'ish. The above applies only for Sierra running gear.
[Edited on 23-7-05 by Hellfire]
Jon Ison
posted on 23/7/05 at 03:58 PM |
i used cortina 3:89 & 15" wheels on my 893cc blade engined locost, top speed was around 130 with 70mph motorway cruising just under 7k revs
Avoneer
posted on 23/7/05 at 05:35 PM |
Depends on what axle and rear set-up you are going to use.
Live, de-dion or fully independant.
That's the decision you need to make first.
Pat...
