John
| posted on 4/1/03 at 01:16 AM |
Front Hub Top & Bottom Swivels
Can anyone advise me of the best source for the Cortina bottom swivels. (or Maxi if Cortina not available).
Also is the best source for the top swivel (transit track rod ends) still A. P. Lockheed, as per book. If yes can you advise me where they are
located.
Thanks.
John.
Working on a CVH 1.8 engined Locost. Hoping to use as much as possible of Sierra donor. £210 left.
Viper
| posted on 4/1/03 at 08:54 AM |
you will get both top and bottom joints from your local motor factors....
theconrodkid
| posted on 4/1/03 at 04:03 PM |
try lolocost for the tops £7 a pair,probly do bottom as well
Duncan
| posted on 4/1/03 at 05:16 PM |
You can get them from any motor factor or from Lolocost near Nottingham. If you get them from Lolocost the top ball joints will cost you £10 for the
pair including lock nuts. Cortina bottom ball joints will cost you £12 for the pair. Contact them on:
Tel: 01623-420734
Fax: 01623422287
E-mail, help@lolocost.com
www.lolocost.com
hope this helps
John
| posted on 5/1/03 at 10:43 PM |
Thanks for help.
John.
