Author: Subject: front uprights and rear axles
Kieran
posted on 24/8/05 at 08:32 PM Reply With Quote
Now that cortina uprights and escort axles getting thin on the ground, whats the alternatives??
Kieran
Gav
posted on 24/8/05 at 09:27 PM Reply With Quote
I went for sierra bits.
Basically to use the Sierra front uprights you cna buy an insert that goes into the top clamp where the suspension strut sat in, this allows the use of the top ball joint, these you can get from GTS or MNR and probably a few others
Also the steering rack body will need to be shortened to fit inside the bodywork, however you then need extenders screwed on the end to then take it out far enough for the original sierra track width, which is 4inch wider than the escort.
for the rear you will either need to design your own IRS or use a dedion bar to mimic the solid axle of the escorts.
Also you will need some mounting plates ofr the dif.
Also due to the larger track width you will need wider wishbones at the front. again these can be bought from some of the kit manufacturers.
HTH
edit: thats a lot of Also's
[Edited on 24/8/05 by Gav]
Avoneer
posted on 24/8/05 at 09:30 PM Reply With Quote
Sierra front end - requires different top front bones though and Sierra rear end with either IRS or DE-DION./
Pat...
niceperson709
posted on 25/8/05 at 12:01 AM Reply With Quote
you can look at the cab forward vans from Toyota and Mitubushi I have used a Lite ace (terago and privia in some places ) live avel is nearly 4 to 1 ratio and will fit the book chassis with FWD ofsett wheels or go +2 and use RWD wheels .
including a pic of the uprights installed Rescued attachment liteace uprights.jpg
Best wishes IAIN
life is not the rehearsal , it's the show so don't sit there thinking about it DO IT NOW
http://iainseven.wordpress.com/
niceperson709
Best wishes IAIN
James
posted on 25/8/05 at 11:39 AM Reply With Quote
Pat...
Pat,
Are you suggesting having a Sierra based standard Locost track at the front but a wide rear?
If one shortens the top wishbone relative to the bottom (so that Sierra uprights can be used) then what effect does this have on the suspension characteristics?
I'm always wary of this as I don't know enough about suspension design to know that this won't produce a dreadful handling car!
James
[Edited on 25/8/05 by James]
Avoneer
posted on 25/8/05 at 03:04 PM Reply With Quote
Don't know James - didn't read the thread properly!
Saying that, the Avon has Sierra back end and the front track is about 2" narrower on each side.
No probelms with the handling with that one - even with the very poor suspension geometry at the front.
Pat...
