paul_mcq
posted on 26/8/05 at 01:11 AM |
splines????????
well ppl hows it going. just wanted to no does any one no were to get a metal tube with an internal spline cut into it? the spline would be for a
drive shaft going into it. let me no cheers.
posted on 26/8/05 at 09:54 AM |
Can't you get a mating part (to the male - external spline) and adapt it? Would be easier as many of the internal splines are made using
specialised tooling so generally very expensive to make low quantities.
paul_mcq
posted on 26/8/05 at 02:28 PM |
its for the rear end of an off road buggy that we are designing and i was thinking of mounting the main cog and bearing on a spline tube and slide in
the drive shafts? if any one no's an other way plz write back.
paul_mcq
posted on 26/8/05 at 02:49 PM |
some thing like this we need
NS Dev
posted on 26/8/05 at 03:09 PM |
what sort of rear engine buggy? What engine and what gearbox.
We use this format all the time in autograss so can probably give you a cheap solution!
paul_mcq
posted on 26/8/05 at 03:17 PM |
the buggy is a full suspension high powered bike engine(hopefully blade) the pic on rite is the drive with cog bearing etc, the problem is conecting
the wheels the the drive, we can't seem t find u-joits or spline tube, help
NS Dev
posted on 26/8/05 at 03:24 PM |
right, thought it would look like that!
the bike engined grassers are much the same.
Make the flanges either side of the sprocket to match sierra "lobro" type 6 bolt flanges (ones on disc brake rear end sierras) and then
use sierra lobro CV joints (will rocommend using sierra rear hubs anyway, nice and easy to mount plus you can buy the mount plates from plenty of
suppliers on here)
then get custom shafts made to the length you require. GB Engineering in Nantwich make them for £70 a piece, splined to suit the sierra cv's and
they are unbreakable.
paul_mcq
posted on 26/8/05 at 03:29 PM |
thought of that but will you be able to put the bearings on with the flange in place?
paul_mcq
posted on 27/8/05 at 05:30 PM |
would the granada have the same shafts as the sierra dicks?
Crazy Jay
posted on 27/8/05 at 07:36 PM |
sorry he meant discs, hes a twat
