Author: Subject: wishbones
jester241uk
posted on 27/8/05 at 07:12 PM Reply With Quote
wishbones
Hi all, can anyone tell me if they foresee any probs making my wishbones out of stainless ie is it to hard and likely to crack under stress over a period of time the welding is no prob as im a llyods registered welder also would like to use poly bushes so what id is best to fit them
cheers
Ian
oh yeah nearly forgot whats the best way to polish them up after
Jon Ison
posted on 30/8/05 at 05:28 PM Reply With Quote
No answers, prob everyone scared too stick there neck out, I'll risk it.......
I made stainless wishbones, rear trailing arms and panhard rod, they all performed fine for me, i made my own bush's, its that long ago cant remember size but i reamed tube out to suit.
When i welded them up i did purge them, i seem too remember a big discussion on that too, not sure its necessary to do this but i did anyway.
I could find and scan some pics if you wish i have no digi ones.
I polished them too a mirror finish on a mop with soap.
Rgds Jon.
jester241uk
posted on 30/9/05 at 06:56 PM Reply With Quote
bit the bullit and made my stainless suspension ,pleased how it came out and best of all it fits!!!!!! also made stainless roll bar and am now in the throws of making stainless inlet manifold for bike carbs total cost so far for stainless bits £0.00 Rescued attachment PIC00095.jpg
omega 24 v6
posted on 30/9/05 at 07:28 PM Reply With Quote
Wow mega nice and shiny. what grade of s/s did u use? If it's a sucsess (spelling) then how many of us would like to have gear like this.
Me for one.
Oh and the price is right so how much for postage
[Edited on 30/9/05 by omega 24 v6]
907
posted on 30/9/05 at 07:31 PM Reply With Quote
I too am building in stainless......
any chance of the name of your material supplier ?
atb
Paul G
jester241uk
posted on 30/9/05 at 07:47 PM Reply With Quote
grade of stainless is all 316 got it all from work (shipyard) went bust a couple of years ago but has since been bought and reopened and its all from stock that has no paperwork so cant use it on ships, to do with insurance from Lloyds i believe but i can use it on my car tho
Unfortunatly i cant do anymore dont think boss would be too pleased didnt mind me having some but "dont take the piss" were his words
Ian
James
posted on 3/10/05 at 08:07 AM Reply With Quote
Look really good!
I'm slightly concerned about the strength of you lower wishbones though. The area where the BJ bolts too is just a bit of plate where it joins the arm tubing.
You sure this is strong enough? There's a lot of strain there.
James
jester241uk
posted on 3/10/05 at 03:31 PM Reply With Quote
James , i dont think it will be a problem the plate is 6mm thick and i made the plate bigger then slotted the tubes so it sits inside them the tubes are 5mm thick ,welded continuous all way round, so i think the part for the ball joint should be ok, thanks for your concern tho
cheers
Ian
rocket
posted on 28/12/05 at 05:51 PM Reply With Quote
you shouldn't use 316 it will crack unless you take it and get it anealed.
304 is what you should use for stressed parts
Rgds
Roger
posted on 29/12/05 at 11:08 AM Reply With Quote
Rgds
Roger
Very much agree so many different types and grades of "stainless" that you have to check out the correct procedures for the type and grade you are dealing with.
With stainless steels pay close attention to the design of the wishbones follow the general pattern of the design used by GTS or the current MK type.
Oridinary plain mild steel is by far the most forgiving engineering material anything else requires careful consideration before using.
