RickyKay
posted on 5/9/05 at 03:34 PM |
Steering Column questions
Hope somebody can help me!! What thickness of plate and what hole size do you cut for the streering column bush. Have column and new bush etc just
need to know what size to make.
Awaiting replies. Cheers
A.J
posted on 6/9/05 at 10:08 PM |
When I produced my support I used 3mm aluminum plate, which I stitched drilled to take the steering column bush. I put a slight bend in the plate to
achieve the correct mounting angle with the steering column.
I them bolted the mounting plate onto the front cross member immediately in front of the driver’s position. (see attached photo)
