Rorty
posted on 8/9/05 at 04:10 AM |
Transit TRE shortcomings?
I seem to remember a thread a while ago (can't find it) where at least two people said the taper stud on the Transit TRE was too short for the
thickness of the upper eye of the Cortina upright, resulting in insufficient threads poking through.
I think they were either going to fit a half height Nyloc nut or grind/machine some metal off the under side of the eye to enable the nut to go on
safely.
Is this a common problem? Is it just related to a particular year or model of Cortina? Or is it related to a particular manufacturer's TRE?
Cheers, Rorty.
NS Dev
posted on 8/9/05 at 07:00 AM |
I think it's just 1 make of TRE. Certainly I had no probs with any of mine, but I have seen one that wouldn't reach, and it was a
different make (couldn't say which make though!)
On my 7, by way of example, at the current "dummy" build stage, i have packed the TRE threads with 4 1mm washers which just stops the
nylon engaging until I know it won't need to come apart again for a while!
Rorty
posted on 8/9/05 at 07:11 AM |
Perfect, thanks.
Cheers, Rorty.
jonbeedle
posted on 8/9/05 at 10:11 AM |
I wondered about that. I had to turn my nylocs to make half nuts.
Jon
"Everyone is entitled to an opinion however stupid!"
Rorty
posted on 8/9/05 at 12:53 PM |
This is exactly the reason we should have a data base; so people can list what works and what doesn't and in this case, which brand of TRE is
too short and which one fits the Cortina upright.
Cheers, Rorty.
Gav
posted on 8/9/05 at 01:44 PM |
Interesting idea Rorty,
If you wanna come up with the basic info that needs to be kept ill looking to writing it out with php/mysql.
Rorty
posted on 8/9/05 at 09:14 PM |
I'm not the first to suggest a database; it's been brought up on several previous occasions. Someone suggested a wiki. I'm not
familiar with what's required with setting it up or hosting it, but it's plainly obvious someone needs to set up some form of knowledge
base here.
Perhaps ChrisW has plans for it as part of the new look site.
Cheers, Rorty.
bob
posted on 8/9/05 at 09:33 PM |
A database would be a brilliant idea,the search system we already have but its very painfull having to drag through threads it throws up for you.
Maybe we should lobby chris to incorporate a database in the new site as rorty has mentioned.
Gav
posted on 8/9/05 at 10:09 PM |
As an interim measure im happy to set up a wiki on my server and pass on the DB if chris decides to incorperate it into the new site
Rorty
posted on 8/9/05 at 10:21 PM |
I would suggest dropping him a line or whatever and offer your services. The more people that put pressure on ChrisW to come up with a data base the
more chance there'll be of succeeding.
It's sorely needed here; it's the one lacking element that would make this site a truly formidable resource.
Cheers, Rorty.
bob
posted on 18/9/05 at 01:10 PM |
I've been having a look into this transit trak rod end and may have found the problem,the book does say TRE but most have found the transit drag
link to be prefered.
Here is a picture of both and you can see the difference in the length of thread,the drag link having the longer.
![](/galpreviews/a258129-top ball joints.jpg) ![Rescued attachment top ball joints.jpg](/gallery/a258129-top ball joints.jpg) Rescued attachment top ball joints.jpg
Rorty
posted on 18/9/05 at 01:36 PM |
There's more to it than that; the TRE is M20 x 1.5 and the DLE is M18 x 1.5, though they share the same taper.
Looking at the photo above, although the tapers are the same, the TRE is stubbier than the DLE. Is this the reason some people have had trouble
getting the nut fully on the taper stud? Do some people/kit manufacturers use the TRE instead of the DLE?
Cheers, Rorty.
bob
posted on 18/9/05 at 02:15 PM |
Basically i believe this has been pointed out as an error in the book elswhere,when i was searching for parts even my local factor said most people
use the drag link and wondered why i was asking for the TRE.
I havnt got any pictures of the lada track rod end which i have also heard people have used,i've heard the lada TRE has the M18/1.5mm thread but
on a longer shaft so this would be more suitable to the slide adjuster system people have used.I'm not sure of the taper or length of the thread
either,but as you have said bob a database would be a good idea and clear up this area of people build.
quattromike
posted on 18/9/05 at 05:55 PM |
Funnie you mention it but when I was making my A arms I was under the impresion that I needed a M18 x 1.5 tap and I went out and bought one but when
it came too it it was M20 and I already had one of those so now I'm happy I have the right parts .
Cheers for that
Mike
posted on 18/9/05 at 07:54 PM |
Cheers for that
Mike
M18x1.5 is the correct size for the drag link end which is what the majority of people use. The book specifies the M18 thread size but incorrectly
refers to the ball joint required as a track rod end. If the track rod end fits in your wishbones ok, and there is enough thread on the tapered part
then you should have no problems however.
