<<  1    2  >>
Author: Subject: Alternative uprights
jonbeedle
posted on 28/9/05 at 11:24 PM Reply With Quote
What's the alternative to Cortina uprights. I may have ruined mine and as they seem to be as rare as rocking horse pooh I thought there must be an alternative. I'd like to keep my Cortina hubs, discs and calipers as they are all new.
Jon
"Everyone is entitled to an opinion however stupid!"
jonbeedle
posted on 29/9/05 at 12:40 AM Reply With Quote
I started looking for a Hyundai Stellar and found an '88 one but I think the uprights were only the same on the '85-'86 models. Am I right?
Jon
timmy
posted on 29/9/05 at 01:56 AM Reply With Quote
A couple of chaps over here in Oz have used LiteAce Toyota van uprights with some success. They may be a bit heavier than the corty ones, but they have more modern brakes (some are even vented!).
The uprights from a Holden/Isuzu Gemini are also quite good, but they might be difficult to find over there.
The only prob with using alternative is trying to get the geometry right....
locost_bryan
posted on 29/9/05 at 04:10 AM Reply With Quote
Vauxhall Chevette/Opel Kadet(?) are Euro versions of Gemini
Bryan Miller
Auckland NZ
Bruce McLaren - "Where's my F1 car?"
John Cooper - "In that rack of tubes, son"
Mix
posted on 29/9/05 at 06:17 AM Reply With Quote
If you don't mind me asking, what did you do to ruin the uprights ?
They may be recoverable.
Mick
MikeR
posted on 29/9/05 at 08:28 AM Reply With Quote
just about to ask the same question and maybe off to take the ruined ones off your hands.
mangogrooveworkshop
posted on 29/9/05 at 11:18 AM Reply With Quote
raceleda do uprights to replace cortina units
iank
posted on 29/9/05 at 12:03 PM Reply With Quote
But they might put you over just the £250 promised by Ron
Capri might be an alternative (used by Sylva on the Riot). Didn't early Sylva's use the Chevette uprights?
Another avenue worth investigating might be FWD uprights. I know GTM managed with driveshaftless mini ones on the coupe.
[Edited on 29/9/05 by iank]
jonbeedle
posted on 29/9/05 at 01:18 PM Reply With Quote
My cycle wing brackets bolt on using the top TRE. This means that the thread doesn't protrude enough once the locknut is fitted. So I had a bright idea. I turned the nuts down to make half nuts. Still it wasn't enough. So I ground down the upright with an angle grinder and took too much off. I underestimated the efficiency of the equipment I was using! Instead of it measuring 22.5mm it now measures 16.5mm. That's a lot of meat to remove and I'm worried it may have weakened the upright. It looks strong enough but you can't afford to mess around too much with a steering component, so I thought I'd get some new ones to be on the safe side (more expense) and then order some brackets which have an alternative fixing method.
Jon
Mick
[Edited on 29/9/05 by jonbeedle]
Mix
posted on 29/9/05 at 01:40 PM Reply With Quote
That doesn't sound too bad on the face of things, I'll have a look at my untouched ones when I get home and post my opinion.
Mick
Arthur Dent
posted on 29/9/05 at 02:30 PM Reply With Quote
85-86 Hyundai Stellar is exactly the same as Cortina. After that they are struts.
'The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong, it usually turns out to be impossible to get at or repair.' Douglas Adams
MikeR
posted on 29/9/05 at 03:53 PM Reply With Quote
if you do want to get rid of them - sling them my way, i might have a novel use for them.
I'm sure a few beer tokens will get slung back.
Mix
posted on 29/9/05 at 04:29 PM Reply With Quote
Ok (prepared to be shot down)
If you have taken the 6mm off of the top of the TRE attachment hole I think you could get away with it.
I say this because:
It is possible to file the upright into a smooth curve here to reduce stress raisers.
The section of the upright as it curves into the area where the TRE is attached will still be of a lesser or equal section to the area where the TRE attaches. (ie you haven't reduced the section below what was already the smallest area)
The amount of metal you have removed is proportionally less as the hole is larger at the top than the bottom.
The upright was designed to take the loads imposed by a much heavier vehicle and not to be scrutinised often, if at all.
I would be confident enough to fit them and take it easy for a while and keep an eye on the TRE attachments. What you have is probably stronger than a lot of alloy equivilents.
At the end of the day you will have to decide what you are happy with.
Mick
posted on 29/9/05 at 04:47 PM Reply With Quote
Don't Westfield mill them down for the same reason, to put a bracket under them ?. I can't see there being any problem with the thickness of metal you have left as long as the taper locks and doesn't show through your bracket. You could weld a 5mm plate on top and drill through it to make it back up.
jonbeedle
posted on 29/9/05 at 05:38 PM Reply With Quote
I ground the bottom of the TRE attachment hole!
I say this because:
Mick
posted on 29/9/05 at 07:30 PM Reply With Quote
Build it back up, you haven't altered the taper so it shouldn't make any difference where you took it from. As long as the nut locks the taper into the hole they should be strong enough at 16mm thick. It should work with a thick washer making up the difference. Rescued attachment tre.jpg
Rorty
posted on 1/10/05 at 06:34 AM Reply With Quote
You don't need to hunt down rare/expensive uprights; just make your own! Rescued attachment upright_01.jpg
Cheers, Rorty.
Rorty
posted on 1/10/05 at 06:37 AM Reply With Quote
Cheers, Rorty.
MikeR
posted on 1/10/05 at 05:48 PM Reply With Quote
couple of questions,
1) where do you get the spindle from?
2) why not make it out of one veritcal peice of steel instead of an angles piece (is this to make it the same as the cortina bit) (edit - 5 hours later, i remember, rod end)
3) where did you get the bits that the ...... arrghh, forgot the word, the bit that you've used instead of a transit drag link?
4) how do you know it will stand up to the strain of road use? ie not checked every 30 miles.
[Edited on 1/10/05 by MikeR]
MikeR
ok, i can't count!
Rorty
posted on 1/10/05 at 09:09 PM Reply With Quote
  1. I either turn conventional-shaped or parallel spindles for my own custom hubs, but you could use trailer stub axles as you're using Cortina hubs.
  2. It's easier to weld the stub axle through a member at 90 degrees to it, but it's also partly to have a simple datum to attach the calliper bracket to.
  3. Rod ends? From any bearing retailer.
  4. In the old days, testing and these days, analysis. I used to make heavier ones but soon whittled them down. The ones in the pic are overkill and heavy for production simplicity and are OK for a 1-1/2 ton Ford pickup; they're incredibly strong. Top shelf ones are even lighter with bolster washers around the bolt holes for strength.
Cheers, Rorty.
MikeR
posted on 2/10/05 at 09:49 AM Reply With Quote
As usual, answers provoke more questions,
1) For the hole builder, wouldn't it be better trying to source bolt on spindles or do you think its easy to weld them together (thinking the average home builder has prob max 150 amps.)
2) ignore the question, i wasn't thinking when i asked it, forgot about trying to get the wheel to camber in corners.
3) I wasn't meaning the rod end itself, but the bit the rod end is going through between the two vertical bits of steel. I'd normally use a bolt and lots of washers / spacer.
4) Any chance of supplying the spec ie thickness / grade of steel used?
Rorty
posted on 2/10/05 at 09:33 PM Reply With Quote
  1. I doubt if you would find any bolt-on stub axles and the cost of turning aa thread on a plain one would far exceed the cost of having someone weld one on (if the DIY welder wasn't up to the job).
    Incidently, I turn down the back of the stub axle to form a 16mm dia. spigot which goes right through the entire box tube and I then rose-weld it to the other side of the RHS. This anchors the stub securely and really beefs up the whole upright.
  2. OK
  3. Ah, sorry. Those are ball extenders! They extend the ball bearing and effectively increase the bearing surface and thus the angle of operability. They also have a convenient spacer built-in. The extenders also step down the size of the bolt through them, normally by just one size, so you'd need to remember that when drilling the holes in the uprights.
    I usually make them up for the job in hand from stainless steel. See pic below.
  4. No worries; the RHS is nothing more than common 50 x 50 x 3 mild steel box tube and the stub axles vary but IIRC, the grade you'd use in the UK is something like EN16. Many trailer stub axles aren't even as good as that yet they hold up OK.
Cheers, Rorty.
stevebubs
posted on 2/10/05 at 10:05 PM Reply With Quote
Yep - and then they moved onto chopped down Mk II Esort units.
gazza285
posted on 2/10/05 at 10:15 PM Reply With Quote
Originally posted by Rorty
  • I doubt if you would find any bolt-on stub axles
  • Could you not use the VAG ones that youmentioned the other day?
    <<  1    2  >>
