sthmach
posted on 4/10/05 at 08:10 PM |
Coil Over Shocks
I'm wondering if 300#Fnt and 220# rear springs will be too much? I have heard that 200# and 250# are the best. I have a toyota 4AGE and
stardard frame design.
What do you recommend????
Tks, Stan
BKLOCO
| posted on 4/10/05 at 08:52 PM |
Sounds far too much to me.
Talking to Darren George of GTS (who is a suspension man) reckons 275 front. 175 rear.
Triton
| posted on 4/10/05 at 08:56 PM |
Comes down to weight of car and how you like that car to behave
www.tritonraceseats.com
www.hairyhedgehog.com
Dale
| posted on 5/10/05 at 01:46 PM |
Shock angle will make a huge difference as well, If your upper bracket is outside the upper rail or under it. The ratio of your lower arm length and
lower shock position makes a big difference as well. A 200 lb shock mounted more vertically could be stiffer than a 300 lb shock at more of an angle
or farther in from the ball joint towards the center of the car.
Dale
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
sthmach
| posted on 8/10/05 at 01:49 AM |
Thanks Guys,
