derf
posted on 21/10/05 at 04:08 AM |
New A arms (pics)
The jig was good enough that the lower arm can be fliped over and fit in either way. The 2 uppers are exactly alike. I fishmouthed all the tubes with
my handy dandy trusty angle grinder, lots of fitting and a little bit of trial and error. I did screw up my first try at a lower arm (not
pictured).
These are built around using s10 steering knuckles, and this design is adjustable for camber, and caster. Toe will be adjustable with the steering
rack.
![](/galpreviews/arms1.JPG) ![before welding in the jig](/gallery/arms1.JPG) before welding in the jig
![](/galpreviews/arms2.JPG) ![before and after in jig](/gallery/arms2.JPG) before and after in jig
![](/galpreviews/arms3.JPG) ![with and without hardware](/gallery/arms3.JPG) with and without hardware
![](/galpreviews/arms4.JPG) ![a closer view of the upper arm jig](/gallery/arms4.JPG) a closer view of the upper arm jig
![](/galpreviews/arms5.JPG) ![size difference between upper and lower](/gallery/arms5.JPG) size difference between upper and lower
![](/galpreviews/arms6.JPG) ![upper and lower together](/gallery/arms6.JPG) upper and lower together
![](/galpreviews/brackets1.JPG) ![The brackets clamp around the heim joint](/gallery/brackets1.JPG) The brackets clamp around the heim joint
chrisf
posted on 21/10/05 at 10:15 AM |
Looks good. I'd put a horizontal brace between the two treaded tubes. As-is, there isn't a lot of welded area for you to trust your life
to.
I've always wondered...On these types of set ups, what keeps the ball joint from dropping through the bottom or lifting ou the top? Is the a
snap ring or something?
Avoneer
posted on 21/10/05 at 11:08 AM |
They look really nice.
Like chris said, I would weld another round bar across the two arms of the lower bone nearer the rose jointed end.
Pat...
derf
posted on 21/10/05 at 12:55 PM |
that was the plan, I also need to cut up some a bracket for the shocks to mount on.
posted on 21/10/05 at 01:37 PM |
What would this actually do? Is it simply to ensure that shear loads are equaly shared by the two rod ends?
chrisf
posted on 21/10/05 at 11:09 PM |
Derf will tell you. As his control arms stand, he can flex them about. Adding the horizontal bar will stiffen it up quite a bit. Of course they will
be stiffer once mounted on the chassis, but why take chances.
--Chris
derf
posted on 22/10/05 at 12:23 AM |
no they don't move at all, but a horizontal bar will definatly create a much stronger unit.
posted on 22/10/05 at 10:47 AM |
Look just dandy to me , I was at one stage toying with something similar using Mini/Metro ball joints.
