Nick Davison
| posted on 29/1/03 at 05:00 PM |
Ride Height
I am fitting longer wishbones to my chassis and therefor my ride geometry will be slightly different, particularly the angle of the shock, it's range
of movement and the increased moment on the shock it's self.
My questions are:-
On a standard set up, wishbones shocks and chassis, what angle will the lower wishbone sit at (in relation to the chassis) when the front suspension
is assembled and the car jacked up so the wheels are off the ground?
Also what range of movement is obtained when the wishbones travel from the lower limit on the shock to the upper limit on the shock measured from the
center of the wheel hub?
How long are the springs and how much are the springs compressed, by use of the adjustable collar (again on a standard set up) to give an acceptable
neutral ride height with a heavy engine fitted, Pinto plus a few pounds?
I have standard 12" shocks and springs fitted to Luego's long wishbones which are normally fitted to their V8 chassis and I need to know what
length shocks and springs to buy.
Nick
[Edited on 29/1/03 by Nick Davison]
JohnFol
| posted on 29/1/03 at 08:00 PM |
To answer your first 2 points I think you need to look at it differently. Consider the mechanical limit of movement without a shock, and then position
the shock accordingly.
ie - remove the shock
Put wishbone fully down, raised it 1cm and recorded the positon.
Then, put it fully up, drop 1cm and record position. Now position shock so at full extent you hit the lower mark, and when compressed you hit the
upper mark.
This may mean the mouting points of the shock may not be as per the book.
Nick Davison
| posted on 30/1/03 at 08:27 AM |
John
Thanks for that it sounds a logical procedure. That would give the maxium travel, I take it that the limiting factor for the range of movement would
be the geometry of the ball joints etc?
Nick
