Author: Subject: Aluminium hubs
joolsmi16
posted on 26/10/05 at 10:16 PM Reply With Quote
Aluminium hubs
Hi all, has anyone had difficulties fitting the oil seals into aluminium hubs.
Have recently bought a pair from ebay for a cortina but I am having difficulties fitting the oil seal it just seem way to big?
I was told they were from GTS tuning if that helps at all.
Any thoughts do I use my big hammer!
Jools
posted on 26/10/05 at 10:24 PM Reply With Quote
i wasnt aware that gts did ally hubs. A hammer sounds a bit extreme though! Try freezing the bearings and heating the hubs first, unless they're blatently not right! Arent standard bearings tapered anyway? With my normal hubs it wasnt even an issue of pressing the bearings in, they fell into place.
ReMan
posted on 26/10/05 at 10:27 PM Reply With Quote
Oil seals are usually a tight fit.
Tight fit is one thing , looking to big another
If it looks more than 1/2mm too big it probably is.
You need to drift them in using an objcet the same shape and size such as a big socket, hit that not the seal.
HTH
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
Avoneer
posted on 26/10/05 at 10:29 PM Reply With Quote
Are you sure they're Cortina and not Mk2 Escort?
Pat...
joolsmi16
posted on 27/10/05 at 08:18 AM Reply With Quote
aluminium hubs
Hi, aren't escort Mk2 and cortina bearing sets the same and therefore the oil seal the same.
I have had a search on the web and the only thing I have found for different aluminium hubs are oversized bearing.
My bearing fit ok but not the oil seal??
Jools
Avoneer
posted on 27/10/05 at 11:14 AM Reply With Quote
What's the diameter of you oil seal?
I'll measure mine tonight and compare.
Possible wrong oil seal???
Other than that, don't know, sorry.
Pat...
Rorty
posted on 28/10/05 at 04:37 AM Reply With Quote
If you post the bearing numbers and seal numbers they can be checked for compatability.
Cheers, Rorty.
joolsmi16
posted on 28/10/05 at 09:00 PM Reply With Quote
aluminium hubs
Hi, I will check diameters and numbers of bearing/seal and will post asap.
joolsmi16
posted on 29/10/05 at 05:52 PM Reply With Quote
aluminium hubs
Hi, I have had a look at bearings/seal
The bearing kit is premier BRT266
The oil seal diameter is 55cm and is to big for my lovely new aluminium hubs"bugger"
Hope this helps
Deckman001
posted on 29/10/05 at 07:05 PM Reply With Quote
I hope it's not the Hub i lent Daren at the Brands show , that reminds me, must get it back off him !!
Jason
Rorty
posted on 30/10/05 at 04:02 AM Reply With Quote
Having got that info I now can't help you with the seal!
All I have here is a reference to the bearing (#0609), but nothing for the seal.
If it's obviously too big, don't force it as you'll damage the seal and the soft aluminium.
Cheers, Rorty.
posted on 30/10/05 at 08:18 AM Reply With Quote
Would it be possible to get the hub turned out in a lathe so that your seal fit? Once had to modify some hubs in a similar way . Or check with your local bearing supplier and see if you can get a seal the correct size?
Deckman001
posted on 30/10/05 at 01:53 PM Reply With Quote
According to the invoice i have from the Timken bearing sets I got for my ally hubs the codes are
LM11749/10 (inner bearings) ?
L44649/10 (outer bearings) ?
40 x 55 x 8 Seals
These fit a std Cortina Hub
Hope it helps
Jason
[Edited on 30/10/05 by Deckman001]
joolsmi16
posted on 30/10/05 at 09:21 PM Reply With Quote
aluminium hubs
Thanks for all your help, if the chap I got them from is unable to help I will get them turned down a little.
Cheers all
Jools
