tks
| posted on 3/12/05 at 09:24 PM |
Steering problem anyone ideas??
Hey guys whats wrong over here??
wy does it disengage..?
Hope some one can tell me..
Tks
Mark Allanson
| posted on 3/12/05 at 09:34 PM |
I cannot see a great deal from the picture, but the plastic part of the bearing which is on the column seems to be the wrong way around.
What exactly is disengaging?
Mark Allanson
| posted on 3/12/05 at 09:36 PM |
..a picture of mine
Looks like the circlip that should be above the inner bush to stop it rising up is missing
| posted on 3/12/05 at 09:38 PM |
As you can see in Marks picture the circlip is about 80/90 mm above inner bush. When bush is in place circlip should just touch top of bush.
Avoneer
| posted on 3/12/05 at 09:51 PM |
Yep, it's all fitted right, but the triangular funny clip thing is missing.
Push the inner bush back down trough the other one and use a tie clip around the shaft to stop it sliding up again.
Pat...
RoadkillUK
| posted on 3/12/05 at 10:28 PM |
I've got one of them spare in the kitchen atm, just had a look to see if it's still there and it is.
If you U2U me your address, I can send you it on Monday.
That's if I don't break it taking it off
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
| posted on 4/12/05 at 12:28 AM |
Put a jubilee clip or a tiewrap round it to stop it riding up. It's because it,s taking up some misalignment.
piddy
| posted on 4/12/05 at 06:59 PM |
The washer/clip that is missing is 36p from Ford.
