sting
posted on 17/2/03 at 02:59 PM |
Ball Joints
Hi All
Was gonna put it as BJ but i thought that some of you might get the wrong idea?
Anyway can anyone confirm that the lower balljoint for use with cortina uprights is an allegro joint as i need to order apair.
Regards
Sting
James
| posted on 17/2/03 at 03:25 PM |
quote: Originally posted by sting
Hi All
Regards
Sting
Erm, unless I'm very mistaken it's a Cortina or possibly Maxi (if your wishbones are suitable) that you want.
The Maxi ones have the benefit of being a bit lighter but you may want/need to modify your wishbones to suit the fact they have only two mounting
holes instead of four.
HTH,
James
P.S. You can get Cortina ball joints, transit drag-link ends and trailing arm ball-joints all from Lolocost quite reasonably (about £6/7 each)
Metal Hippy™
| posted on 17/2/03 at 03:27 PM |
I bought a pair from a Newark autojumble a while back a fiver a piece.
Currently not sure if I'll need them.
You want them, you can have them a tenner anyway.
Can get hold for tomorrow evening....
President of the Non-conformist Locost Builders Club. E-mail for details...
Metal Hippy™
| posted on 17/2/03 at 03:28 PM |
Additional...
Also in Lincoln, it's just the car isn't here...
sting
| posted on 18/2/03 at 02:17 PM |
what a plonker i am. I meant maxi Doh!!!!!!!!!!
with the lower arms i have only 2 bolt holes hence not going the cortina route.
holds head in shame
Sting
Metal Hippy™
| posted on 18/2/03 at 02:21 PM |
Tsk
James
| posted on 18/2/03 at 03:17 PM |
holds head in shame
Sting
I'm not exactly sure about this but be a little careful about rushing to buy the Maxi joints.
Others can give a more expert opinion on this matter but there's quite a difference between The Book wishbones (designed for Cortina) and MKeenan's
ones (Maxi BJ) as regards the area of the w/bone where the BJ bolts on.
The MK wishbone has a circular hole for the Maxi whilst The Book has only a much weaker (IMO) 'U' shape.
All I wonder is if the 'U' shape is suitably strong enough for the Maxi which has only the 2 bolt holes.
For all I know you may have MK wishbones anyway so this point is somewhat academic but I thought it was worth considering!
HTH,
James
Findlay234
| posted on 18/2/03 at 03:33 PM |
Hippy you said you had BJ's lying around....... are they Maxi BJ's and are you trying to get rid of them....... unless sting wants 'em ill take
'em!!
cheers
fin
Metal Hippy™
| posted on 18/2/03 at 03:34 PM |
Nope.
Cortina.
Findlay234
| posted on 18/2/03 at 04:30 PM |
shucks!!!!
cheers anyway
Metal Hippy™
| posted on 18/2/03 at 05:06 PM |
Sorry F18 boy
Jasper
| posted on 18/2/03 at 07:40 PM |
I got Merlin's wishbones, and they only have 2 holes for ball joint bolts. As they are only small holes I've welded a new angled piece to take the
two big bolt holes on the Cortina ball joints. They just didn't look strong enough.
sting
| posted on 26/2/03 at 11:01 AM |
Sorry all been away for a bit, anyway thanks for the remarks but my wishbones will only take a maxi i think as it has one circular hole and two bolt
holes only so i think its a maxi that i need?
Thanks all the same Metal Hippy.
Sting
eddymcclements
| posted on 26/2/03 at 11:56 AM |
Yes - if you've got a single round hole in your lower wishbone it's a Maxi balljoint. Note that if your wishbone design mounts this on the upper
surface then the two bolts holding it on need to be very strong! I would suggest using 10.9 high-tensile bolts and suitable nuts with some type of
self-locking action.
Eddy
sting
| posted on 26/2/03 at 12:13 PM |
what if your able to mount from underneath?
cheers
Sting
eddymcclements
| posted on 26/2/03 at 01:33 PM |
Should be OK. There's no way the two lugs on the BJ are going to pull through the hole in the wishbone. On the Maxi BJ's I've seen the part below
the lugs is a slightly smaller diameter than the part above, so you may find that you can only fit them from above - it'll depend how big the holes
are, of course.
Eddy
Fast Westie
| posted on 27/2/03 at 11:03 AM |
quote: The MK wishbone has a circular hole for the Maxi whilst The Book has only a much weaker (IMO) 'U' shape.
Westfie1d wishbones have a U shape and they are prefectly strong enough. Even for embarasing moments like this
[Edited on 27/2/03 by Fast Westie]
The car in front is a Westfield
sting
| posted on 28/2/03 at 05:43 PM |
Maxi joints fitted last night on top of wishbone(won`t fit from underneath)so purchased 12.9 high tensile bolts. thanks for the advice.
Had a nightmare with the top transit drag links tried 2 different model years both incorrect.
looks like a trip to mansfield and lolocost!!
cheers Sting
dozracing
| posted on 11/3/03 at 08:14 PM |
If you need Maxi ball joints i have 10 in stock see my website for details.
www.gtscougar.freeserve.co.uk
Kind regards,
Darren
