timbo7
| posted on 2/1/06 at 11:06 AM |
What handbrake kit?
Need abit of direction here guys.
I need a handbrake kit for my Stuart Taylor ZX9R running english axle and sierra rear calipers on MKII discs.
I want to mount the handbrake on the trans tunnel top.
What list of parts do I need (either part specific or donar model specific) and where from? ie. Partco?
Does the donor cable need modified.. if so how?
Do I need a handbrake light switch for SVA?
Cheers guys.
WESTFIELD HAYABUSA 1400 - SOLD
| posted on 2/1/06 at 01:04 PM |
Sounds like you'll have to make a cable to suit whatever you use, so just find a handbrake that fits your purpose and use that. The Sierra
handbrake and cable is usable and would fit your calipers but you'd need it shortening. You don't have to have a handbrake warning light,
if you can't see it on the top of the tunnel you need specsavers .
[Edited on 2/1/06 by Peteff]
| posted on 2/1/06 at 03:51 PM |
Althougth you don't need a handbrake warning light/switch it is a handy means of testing the brake fluid level warning light . (uses same light)
CairB
| posted on 2/1/06 at 04:00 PM |
Hi Timbo,
Good to see you found the site. Sorry you found the.......!!
AFAIK you do need a red brake fluid low indicator and a means of testing the lamp.
It is common to use the handbrake switch to perform this function as well as a button on the reservoir.
Have you got a copy of the latest SVA manual. Unfortunately mine is from Dec 2000, I think that there have been a few revisions since then.
Colin
| posted on 2/1/06 at 06:08 PM |
? cryptic message query.
Manual link here with revisions up to March 2004 if he wants to read it or download it. It
doesn't tell you what kind of handbrake to use with Sierra calipers though.
Have you used bolt on brackets for the calipers, and MkII what disks are they? I have the Capri axle and am looking at a way of converting it to disk
as the drums are knackered and new ones are a bit steep even with discount.
RazMan
| posted on 2/1/06 at 06:33 PM |
How about the Sierra handbrake then?
You can then use the standard cable too.
You can make it look half decent with a Richbrook cover and gaiter.
Raz
timbo7
| posted on 2/1/06 at 07:27 PM |
Hold on to I get my shades on.... seems to be a very large glare from screen after that post
timbo7
| posted on 2/1/06 at 07:34 PM |
Hi Colin... yeh.. found it... I'm now on that many forums I haven't enuff hours in the day to get through them.
Pete... Colin is refering to MCOB (Miserable Caterham owning Bastards' thread.
Pete... do you want a few pics of my disc set up on the english axle? I currently have the axle apart on the garage floor. I've taken the
staggers and completely stripped the race car to get it fully painted. Also I'm moving to Class 9 from Class 3 for the 2006 race year which
requires road going mods. Yes I have used mounting brackets for the calipers. Discs are Mark11 escort.
| posted on 2/1/06 at 07:48 PM |
It would be handy to see how it's done. Could you put a couple in your archive? Are you going from bike to car engine in the new class,
I'm slowly building a ZX9 engined Locost at the moment, I have a Pinto in the one I have now.
RazMan
| posted on 2/1/06 at 07:53 PM |
'tis a trifle bright innit
Raz
timbo7
No... I'm going from Class 3 lightweight bike engine to Class 9 "fully of heavy unneccessary MOT passable sh*te" bike engine.
The reason is that in Class 3 I'm up against 2.0 Swindon XE's, Darrians with Millingtons, Busa's etc.. so I'm getting a little
bit arse whipped. In Class 9 I'm up against a bigger no. of 900-100cc BEC & class A tyres as opposed to slicks.
timbo7
| posted on 2/1/06 at 08:06 PM |
Pete - YHM
| posted on 2/1/06 at 08:22 PM |
Cheers Tim.
Well lightened by the look of them
timbo7
| posted on 4/1/06 at 10:37 PM |
Darren at GTS can supply me a modified kit complete to suit sierra. Am picking up at Autopsort next Friday. Will let you all know of suitability.
