lee201283
posted on 23/2/03 at 09:08 AM |
can i grind the web off the capri axle because my mate said its the best way?
Mark Allanson
| posted on 23/2/03 at 11:42 AM |
I thought of doing this, but ford must have put it there for a reason. It is so easy to mod the chassis to make it fit that I didn't want to take the
chance ofit breaking - See the thread under this
Rorty
| posted on 24/2/03 at 02:56 AM |
lee201283:
The best way to do what?
If you do decide to grind any webs off the axle, make sure your M8 is the solo test pilot!
Cheers, Rorty.
Metal Hippy™
| posted on 24/2/03 at 03:20 AM |
I've got a Capri axle sat in the workshop and getting rid of the webbing would almost certainly make it a lot weaker...
Granted the car weight isn't anywhere near that of a Capri, but still....
President of the Non-conformist Locost Builders Club. E-mail for details...
lee201283
| posted on 24/2/03 at 08:00 AM |
ive been advised to leave 10 mm of webing left
Mark Allanson
| posted on 24/2/03 at 08:01 PM |
Dont do it Lee, there is no need. Think of all the work that you are going to put into the axle, all the bracketry, cleaning, painting etc - and then
you crack the case, or the pinion bearings keep banging out because the casting is not stable, or worst case - the pinion breaks loose, takes the prop
with it and rips off you left leg at the hip, as well as the lovery car you have just made.
As I said before, give me your email address and I will send you a pdf with all the measurements to alter the chassis
Mark
