quattromike
posted on 8/1/06 at 03:53 PM |
How much offset do you have
Finaly got round to making my sierra upright insert. I've gone with a 25mm offset to try and bring the KPI angle up a bit.
quattromike
| posted on 8/1/06 at 03:56 PM |
and here it is fitted to the upright with the transit track rod end for the balljoint
caber
| posted on 8/1/06 at 04:09 PM |
That looks like a nice piece of machining!
BNTW managed to drop that Pinto 1600 on my foot the other day! no boned broken but much swearing!
Caber
omega 24 v6
| posted on 8/1/06 at 06:13 PM |
Looks nice and jeez what a posh workshop with brass electrical fittings,
Is the machined part alloy or steel?
If alloy are you not worried about the strength around the ball joint area.
| posted on 8/1/06 at 07:14 PM |
1960s Lotus Elan 9 degrees KPI
Lotus Elise 12 degrees KPI
Pug 306 Gti 11 degrees KPI
I some japanese fwd cars run 14 to 15 degrees
quattromike
| posted on 8/1/06 at 09:51 PM |
Yes we are posh up here in Aberlour
Na just some old ones that were changed from the house coz they were worn (cheap as chips) so we had them lying about when we fitted up the sokets in
the garage.
And yes they are aluminium, It is a bit of a concern that the taper will wear, I'll have to keep an eye on it when it finally hits the road.
Sorry to hear about your foot caber . You'll just have to find a suitable brick to lay on the throttle of that rumbling range rover
Mike
| posted on 8/1/06 at 11:13 PM |
That's moved the top wishbone up a couple of inches over the usual "mushroom" inserts. Are you also moving the top wishbone chassis
brackets up by the same amount.
quattromike
| posted on 9/1/06 at 04:13 PM |
I'm not making the book chassis, Mines a bit bigger, It'll be a bit of a One off in that way but still the same Idea.I've not made
the wish bones yet either , thats the next task.
Mike.
