Author: Subject: axle oil change - how?
posted on 10/1/06 at 03:00 PM Reply With Quote
I think the answer is "with great difficullty"
now the question;
How do you change the oil in the mk 2 escort Timken axle (is that English axle? - diff loads in from the front)?
There is filler plug but no drain plug. I have no idea what debris/s'udge is in it....
forgot to say I will be taking both half-shafts out in order to fit the rear brake assemblies, maybe insert a tube and suck?
[Edited on 10/1/06 by 02GF74]
timf
posted on 10/1/06 at 03:30 PM Reply With Quote
if as you say your taking both half shfts out speend £1 on a gasket and remove the diff from the front
RichardK
posted on 10/1/06 at 06:59 PM Reply With Quote
ybe something like this http://www.diy-boat.com/Pages/Archives/links/demooil.html won't help the sh!te but will get the oil changed
Regards
Rich
posted on 10/1/06 at 07:17 PM Reply With Quote
Just put it in the shed the wrong way up and it'll empty itself onto your floor via the breather or take the drain out and lie it on its back with a pan under it. I've only ever refilled or topped up as the stuff stinks too much to empty it and leave in the bin. If you're taking the half shafts out stand it on one end.
posted on 11/1/06 at 10:39 AM Reply With Quote
low cost but a fair buit of work since ht propshaft needsto ome off, etc:
think I'll still in a tube into the filler plug to a pump see what happens...
