Author: Subject: what calipers
locoboy
posted on 1/2/06 at 08:35 PM Reply With Quote
what calipers
I got my recon front calipers yesterday and tried them on my upprights with my 235mm Diameter (approx) vented disks. The disks fit on the upright but the caliper wont bolt to the upright bacause the diameter of the disk is too large.
Do i need new calipers that accommodate larger disks (do they just have longer lugs with the mouting holes in?)
or do i need different uprights with longer lugs with the caliper mouting holes in?
If its the callipers i need to change does anyone know what model of sierra i need to get them from to suit a 235 (approx) diameter vented disk?
Many thanks
Locoboy
lsdweb
posted on 1/2/06 at 08:47 PM Reply With Quote
You could turn the discs down if it's not too much?
Wyn
locoboy
posted on 1/2/06 at 10:17 PM Reply With Quote
No facilitles to do so Wyn, besides its about 20mm i think.
its a fairly standard set up......Vented disks and sierra callipers i just need to know if its my upright thats wrong or my capplier?
Locoboy
Johnmor
posted on 1/2/06 at 10:23 PM Reply With Quote
Discs
As far as I know there were two sizes of front vented discs on sierras, 260mm(ABSmodels) and 240mm .
The calipers are different on each model with larger pistons and larger surface area on the pads but the mounting holes were the same. So if the calipers are for vented discs they should fit.
Earlier models had solid discs so maybe the calipers are for that type.
Sorry cant be of more help
locoboy
posted on 1/2/06 at 10:32 PM Reply With Quote
Cheers John,
I seem to remember that the 2.3diesel has vented disks, i shall ask my supplier to get a pair of them and see if they fit.
Locoboy
aerobrick
posted on 1/2/06 at 11:44 PM Reply With Quote
Try asking on this forum I am a member
the guys and gals have done it all to mod sierras so they will give you an answer
www.fordsierraclub.co.uk.
They are a happy helpful lot who dont mind us cos at least some of the bits live on
NS Dev
posted on 2/2/06 at 12:02 AM Reply With Quote
Many thanks
I don't understand this at all!
The smallest dia discs that were fitted to sierras were the 240mm x 25mm discs as fitted to fwd escorts etc as well.
If the disc is too large then are you sure they gave you the right discs and not the bigger ones???
There are no discs smaller than 240mm (approx) fitted to this generation of fords, and there's no need to ask for 2.3 diesel discs, all the later sierras had vented ones, from the 1.6 through to the 2.0.
As was said, the ABS models had bigger discs and the 4x4 models had a different offset on them too.
lsdweb
posted on 2/2/06 at 08:17 AM Reply With Quote
Hi Locoboy
It's a shame you can't turn the discs down - there has to be an easier way than buying new calipers!
I don't know much about the Sierra setup although I had it on my Fisher Fury a few years ago but my memory is not what it used to be!
Wyn
RichieC
posted on 2/2/06 at 08:38 AM Reply With Quote
Yeh, second what NSDev says. Theres no way they should need turning down or anything if they are in fact the 240mm discs. It sounds as though they are larger than 240s.
locoboy
posted on 2/2/06 at 09:11 AM Reply With Quote
I had the disks off a mate who ran them for a bit on his Mk Indy with sierra callipers (i am trying to find out which ones)
so they do fit under 'some' of the sierra calipers.
Just not the ones i have they have not been used so i can swap them for the right ones no bother.
Tried to upload a photo but i wont work at the moment.........
The callipers do bolt directly to the upright dont they? im not missing a mounting plate or anything silly am i?
[Edited on 2/2/06 by locoboy]
Locoboy
NS Dev
posted on 2/2/06 at 10:38 AM Reply With Quote
Yes, they bolt directly to the uprights. Measure the actual disc diameter, I'll take a very good bet that they are the 260mm discs not the 240's.
a pair of new 240mm discs is £20 or so, so don't worry about it just buy a new pair!
locoboy
posted on 2/2/06 at 11:39 AM Reply With Quote
just taken the disk off and measured it, 240mm x 25mm
does this mean that the upright is wrong or is it that i have solid disk calipers?
Locoboy
NS Dev
posted on 2/2/06 at 01:23 PM Reply With Quote
gawd knows!
I thought the solid discs were 240mm as well, so if the OD is the problem then I have no idea.
If the calipers are solid disc ones then they won't fit but the disc od won't be the issue if the solid ones are 240mm (and I'm sure they are)
RichieC
posted on 2/2/06 at 01:38 PM Reply With Quote
All solid front discs were 240, but you could get them in vented too.
All 260 front discs are vented.
posted on 2/2/06 at 03:21 PM Reply With Quote
Post a picture of the calipers --- might give us some clue
locoboy
posted on 2/2/06 at 03:52 PM Reply With Quote
cant post piccy at the moment - pooter playing silly buggers.
Might it be a rear caliper i have instead of a front?
With the piston pushed back flush, and new pads in i can get the 25mm thick vented disk in between them - would that make it a vented disk caliper as opposed to a solid disk caliper?
Locoboy
locoboy
posted on 2/2/06 at 04:58 PM Reply With Quote
Col asked me to post this for him, and amusingly he's left this site cached on my PC hence logged in as him.
Anyway here's the piccy he was referring to:
Click Me - Big Pic
I had to host it externally, since the upload feature is playing up.
Locoboy
iank
posted on 2/2/06 at 05:01 PM Reply With Quote
I'd guess it failed to upload coz it's 660K.
Try making it a tad smaller (200K ish)
NS Dev
posted on 2/2/06 at 06:09 PM Reply With Quote
Well that answers your problem!!!!!!!!!!!!!!!!!!!!!!!!!!!
Sorry mate, had to laugh!!!
That's only half the caliper!!!
You need the mounting brackets for it too (the part you have there slides on "slides" on the bracket which go through the holes you are trying to line the bolts up with), these won't come with the recon caliper, you use the old ones from the donor.
[Edited on 2/2/06 by NS Dev]
locoboy
posted on 2/2/06 at 06:29 PM Reply With Quote
PMSL,
Im sure i said a few months ago that im crap with Sierra bits,
Guess that confirms it
.........What a goon!
Does anyone have a piccy of their brake set up from the inside as opposed to the normal shots of the outside of the disk and caliper.
In my defence i did think to myself
These sierra brakes must bend the disk or wear the inner pad an awful lot more than the outer one!
Locoboy
NS Dev
posted on 2/2/06 at 10:39 PM Reply With Quote
LOL
don't worry mate! I have done much more silly things in my time, and at least you know it's nowt difficult to solve now!
If you don't already have the brackets from a donor then pop to your local scrappy, they won't want much for a pair of brackets at these don't really go wrong, it's the caliper bit itself that seizes etc (the bits that you have already!) so they will be cheap.
If you go to the scrappy and look at a sierra it will all become obvious to you. Worth a check in the wanted section in here in case somebody has some spare brackets (I don't unfortunately!)
cheers
Nat
Danozeman
posted on 3/2/06 at 06:33 AM Reply With Quote
I got worried then as those uprights used to be mine. I had the vented discs and calipers for them so i knew they fitted.
As said u need the carrier for the caliper. Easily got from a scrappie.
Dan
RichieC
posted on 3/2/06 at 07:55 AM Reply With Quote
Heres what youre looking for: Rescued attachment Brackets After.JPG
locoboy
posted on 3/2/06 at 03:19 PM Reply With Quote
Cheers fellas!
Scrapyard here i come.
Locoboy
locoboy
posted on 5/2/06 at 12:48 PM Reply With Quote
Misson accomplished, it all became clear when i took the sierra wheel off!
only 3.50 for the pair too
Locoboy
