Author: Subject: Braided brake lines
gary gsx
posted on 2/2/06 at 10:57 PM Reply With Quote
Braided brake lines
Ello all
When fitting braided brake flexi pipes to front calipers are the pipes longer or standard sierra lenght??
I thank u
[Edited on 2/2/06 by gary gsx]
RazMan
posted on 2/2/06 at 11:02 PM Reply With Quote
It really depends on the type of unions & calipers you have fitted. I've got Goodrich lines tie wrapped to the lower wishbone with a 'curl' to allow for steering movement. It is best to measure what you need with some washer tubing as a guide.
Raz
Danozeman
posted on 3/2/06 at 06:27 AM Reply With Quote
My fronts are 50cm with banjo fittings to cortina calipers. I think sierras are a bit shorter than this.
Dan
gary gsx
posted on 3/2/06 at 01:40 PM Reply With Quote
Once measured where is best place to get um from??
Danozeman
posted on 3/2/06 at 04:09 PM Reply With Quote
Rally design seem reasonable priced and will make them up for you.
Theres a new set of lotus 7 ones on ebay at the min for 25 quid buy it now. Not sure if the ends will be the same.
Dan
posted on 4/2/06 at 09:59 AM Reply With Quote
take a look at thinkauto webshite. I bought braided hose and fittings for a Land Rover clutch line, now that is bling!
