omega0684
| posted on 6/2/06 at 02:15 PM |
steering dilemma
hey everyone, i was thinking about the steering that i want to put in my dax, since my donar has power steering,im a bit stuck as im using a pinto
engine. i was thinking of going for an mk2 2.4 turn quick rack that i have seen,( anyone know where i can pick one up on the cheap) but i need some
advice on a few things, first of all will it fit? and will the sierra column fit onto the escort rack, or will i have to mod it in any way. any
suggestions welcome
cheers guys
Alex
chrsgrain
| posted on 6/2/06 at 02:21 PM |
Use the sierra one - power steering doesn't matter, the bit of the column used is before the sterring pump.
Chris
NS Dev
| posted on 6/2/06 at 02:50 PM |
oh no here we go again!
not a good idea to use the sierra pas rack without the hydraulics connected (in my opinion, having done it on my old rally car) even if you do gut the
seals and piston out of the casing.
get a manual sierra rack and spend the £100 on a quickrack kit from rally design.
do the job right to start with and you won't regret it later.
If you go for the escy rack, check rally design (www.rallydesign.co.uk) they have some super cheap new escort quickracks, £70 iirc.
Bluemoon
| posted on 6/2/06 at 02:51 PM |
Indeed.. see http://www.locostbuilders.co.uk/viewthread.php?tid=37653
We still need a FAQ...
chrsgrain
| posted on 6/2/06 at 02:54 PM |
Guess I ought to clarify my last posting;
Dax only use the sierra column, and adapt that with some clever welding... the colum then goes into an intermediate shaft (to get the offset needed
for SVA crash protection) then into a 3rd party rack.... hence you can use the column from a PAS sierra as its before the power steering pump.... but
not the rack - which AFAIK won't fit anyway.... also beware quick racks with the large tyres taht the Rush uses, as the steering will be
heavy!
Chris
smart51
| posted on 6/2/06 at 03:02 PM |
The sierra upper column ends in a triangular tube. You have to get a link made to go from here to the rack as the donor car link is too short. Have
your link made to fit both ends
NS Dev
| posted on 6/2/06 at 03:04 PM |
why do they need the column offset if they are using the crushable sierra column?
chrsgrain
| posted on 6/2/06 at 03:08 PM |
Don't know.... that was the explaination given to me by the guys there....
The really funny thing is that the steering is one of the things allegedy from the donor on the DVLA registration form!
Chris
PS did you (NS Dev) have to space out your clutch slave cylinder, if so how??
JAG
| posted on 6/2/06 at 03:10 PM |
Or you can lengthen the original link from the Sierra by welding a section in the middle. That's what I did - the splines on the Sierra part
match the Escort rack exactly
Justin
jambojeef
| posted on 6/2/06 at 06:18 PM |
New Escort racks with 2.4 tltl are £79.50 from Rally Design!
If they'd been doing this offer when I needed mine Id have jumped at the chance!
Geoff
omega0684
| posted on 7/2/06 at 12:46 AM |
i saw the escort quick rack at rally design and that is the one that court my eye. ive been told that i will need extensions put on the ends of the
rack as the dax uses the sierra rack. could i leave the extensions off and have the wheels a bit closer to the chassis to give the car a bit of a more
aggressive look from the front, or would it be unsafe, am i right in saying that i will need a mod to connect the sierra column to the escort rack or
would it be better to get a sierra quick rack if the is such a thing?
cheers for the help guys
Alex
NS Dev
| posted on 7/2/06 at 12:59 AM |
Geoff
Yup, bugger!!! Paid full "pre-bargain" whack for mine!!!
NS Dev
| posted on 7/2/06 at 01:03 AM |
Chris
Yesm guessing from the post that you know I used a concentric setupm with a saab 900 cyl and bearing.....
piccy:
  cr1
sorry it's a bit blurry but its a big lump of ally machined to accept the saab cyl and machined on the back to sit over the cut down trumpet
housing on the front of the box.
E=was going to replace it entirely with an ally piece but....
a) my free lump of ally was too thin!
b) was worried that the bearing circlip might hammer the ally a bit and upset the input shaft position (Think this was an unnecessary worry but a)
already made my mind up!)
Stu16v
| posted on 7/2/06 at 09:28 PM |
Some Sierra shafts WILL NOT fit an Escort rack (I think the models fitted with PAS IIRC)
NS Dev
| posted on 7/2/06 at 09:56 PM |
thats dead right Stu, the PAS spline is quite a bit bigger.
