chrisf
posted on 9/2/06 at 03:49 PM |
Brake hardline to flexi interface
Gents:
How do you guys connect the brake hardlines to the flexi when there is an aluminum/fiberglass panel in the way? Seems like one can connect a braket to
the chassis through which the male hardline passes and connects to the flexi. If doing so, one will need to drill a big, 1" hole through the ali
panel to allow the flexi to pass through.
Or...
Do you guys drill a small hole in the ali panel though which the male hardline passes and interfaces with the flexi? If doing it this way, would there
not be constant stress on the ali panel everytime the suspension moves about?
--Thanks, Chris
[Edited on 9/2/06 by chrisf]
posted on 9/2/06 at 04:04 PM |
I used a flexi hose male bulkhead fitting - the threaded part is extra-long - which was bolted directly to the ali skin. I did put extra-large
stainless steel washers on both sides to spread the load (sold as 'penny washers' in some places, 'repair washers' in others).
I got the largest I could find, and drilled out the holes to 10mm clearance.
Oh - I used a smear of sikaflex to glue the washers in place, and to make it more rigid.
MartinDB
posted on 9/2/06 at 05:06 PM |
Found some pics of mine.
![](/galpreviews/Locost1.jpg) ![Front Apr 07](/gallery/Locost1.jpg) Front Apr 07
![](/galpreviews/2locost2.JPG) ![Paneling 2](/gallery/2locost2.JPG) Paneling 2
The fixings were part of the flexi as they were supplied by Sylva.
Martin.
Danozeman
posted on 9/2/06 at 05:13 PM |
MIne are as above too.
Dan
chrisf
posted on 9/2/06 at 05:25 PM |
Thanks, gents. My flexis look at bit different, as shown below. Any ideas on how I should go about this?
--Thanks, Chris
![](/galpreviews/a322866-DSCN0075.JPG) ![Rescued attachment DSCN0075.JPG](/gallery/a322866-DSCN0075.JPG) Rescued attachment DSCN0075.JPG
chrisf
posted on 9/2/06 at 05:26 PM |
Here is how I currently have the system plumbed in the front. See how my ali panel sticks out from the chassis a bit...
![](/galpreviews/a322867-DSCN0076.JPG) ![Rescued attachment DSCN0076.JPG](/gallery/a322867-DSCN0076.JPG) Rescued attachment DSCN0076.JPG
