auzziejim
| posted on 11/2/06 at 10:24 PM |
shock spacer
been fitting up the rear end on my indy today and found that the gaz shocks are too small at the base to mount to the mk upright
i have tried searching the srchives but found nothing on shock spacers! so do i just pack out with washers or is there a better method?
also can anyone point me in the right direction for a petrol tank that will fit the mk indy but wont cost the earth? i dont trust my welding quite
enough
Triton
| posted on 11/2/06 at 10:40 PM |
Better to have some ali spacers made up than use washers...well i think so anyway.
Have you tried ebay for a petrol tank?
www.tritonraceseats.com
www.hairyhedgehog.com
auzziejim
| posted on 11/2/06 at 10:43 PM |
there seems to be no tanks on ebay that are appropriate and i dont want to buy and find it not fit.
i had the same feeling about the shock spacer does mk supply these?
Triton
| posted on 11/2/06 at 10:47 PM |
Not sure so best bet would be to ring MK and ask them.
Have you tried Mac#1 for a petrol tank?
pathfinder
| posted on 11/2/06 at 10:51 PM |
i got an mk tank from ebay a couple of weeks ago, only £70 and its top quality! think mk put a few bits on there every now and again!!!
Triton- how are my seats coming along?
MkIndy7
| posted on 11/2/06 at 11:22 PM |
From what I remember our shock mounts are spaced out with Washers, and more than likely some of the wishbones as well, thought most MK's were
like that.
Avoneer
| posted on 12/2/06 at 12:22 AM |
MK Engineering sell the tanks on ebay, not MK Sportscars.
Give Martin a ring - I'm sure he'll have a few for sale.
Pat...
indykid
| posted on 12/2/06 at 02:32 PM |
would someone please explain the difference between a solid spacer and packing out with washers from an engineering view point? i'm guessing
there is no difference.
surely once it's nipped up, the washers become effectively a solid spacer.
my shocks are spaced with washers btw. they will be in the new build too.
tom
MkIndy7
| posted on 12/2/06 at 10:24 PM |
I'd guess none too Tom, my dad obv didn't think it was worth making solid ones or he would have!
I think there's only 1 either side of the shock or wishbone and at most 2 on ours so they are practically a solid spacer.
Jon Ison
| posted on 12/2/06 at 11:09 PM |
Out of focus pic but here's what I use, spacers drilled out too take a M12 bolt and turned down on ends too slip into (knock in fit) the
1/2" shock mounting.
Gives a very snug slop free fit and means I still only need my metric socket set.
Gav
| posted on 12/2/06 at 11:33 PM |
Did you make then Jon or can you buy them from somewhere? as i need a load for my suspension.
NS Dev
| posted on 13/2/06 at 12:18 PM |
I've used washers on my build, would normally turn up spacers but I really couldn't be arsed this time, and I have 1/2" bolts with
1/2" bushes and 1/2" washers.
Silly heavy bolts but keeps it all simple!
DarrenW
| posted on 13/2/06 at 01:27 PM |
Yep, washers on mine too. Im an engineer and cant find fault with this method if the sizes all match up.
I think some shockers have a thicker ring so wishbone mounts are therefore universal.
