Author: Subject: driveshaft - which end is which?
ned
posted on 14/2/06 at 04:00 PM Reply With Quote
I have on the bench at home the longer of the two sierra driveshafts. I didn't mark which was the inboard and outboard ends when dismantling. One end has some marks, like a cross marked on it and the other doesn't. Can anyone tell me which end is which?
Thanks,
Andrew.
beware, I've got yellow skin
donut
posted on 14/2/06 at 04:14 PM Reply With Quote
I think they are the same so it don't matter...maybe wrong though! (well that's covered myself!! )
NS Dev
posted on 14/2/06 at 04:22 PM Reply With Quote
I know your worry, but I think the std sierra lobro type shafts (assuming that's what you're using Ned) are so over engineered for this application that they will be fine fitted the wrong way round.
ned
posted on 14/2/06 at 04:29 PM Reply With Quote
yes they are lobro type, thanks for putting my mind at ease
amalyos
posted on 14/2/06 at 04:39 PM Reply With Quote
I had the same problem, but if you check the part number of the Lobro joint on each end, it's the same
Dusty
posted on 14/2/06 at 04:51 PM Reply With Quote
It's not good practice to fit them so they rotate in the opposite direction to their previous working life. Increased risk of breakage. Any witness marks on the joints which might match up to flanges?
iank
posted on 14/2/06 at 05:04 PM Reply With Quote
Isn't it bad practice to rotate used driveshafts the wrong way? I'm sure read they can snap under high torque if installed the wrong way round as they take a 'set'.
posted on 14/2/06 at 05:07 PM Reply With Quote
the forces are the same way which ever way you if it, and id guess its the force which wears it, not the rotation.
jon_boy
posted on 14/2/06 at 05:36 PM Reply With Quote
Except it would twist it the other way to what its used to which would prob weeken it, bit like twisting a rope so the threads come apart. Sould be ok with these though as said.
speed8
posted on 14/2/06 at 05:48 PM Reply With Quote
Eh... what side does the long one go on, driver or passenger? I don't have my diff yet so just checking.
donut
posted on 14/2/06 at 06:12 PM Reply With Quote
AHA!! i was right!! YAY!
posted on 14/2/06 at 06:50 PM Reply With Quote
i cant be arsed arguing, but the force would be the same, much in the same way that a nut can go on either way, or a cork screw could go in backwards.
Liam
posted on 14/2/06 at 06:58 PM Reply With Quote
As JoelP says, swapping a shaft end to end, but keeping it on the same side of the car will not reverse the direction of the torque it is subject to. Think about it
Liam
Stu16v
posted on 14/2/06 at 07:01 PM Reply With Quote
Liam
Agreed...
iank
posted on 14/2/06 at 07:07 PM Reply With Quote
The effect I read about wasn't anything to do with the force, it's closer to metal fatigue, which is why I mentioned used driveshafts, new ones aren't the problem.
Avoneer
posted on 14/2/06 at 10:44 PM Reply With Quote
Let's face it - does anyone know anyone that has ever snapped a Sierra shaft ???
Pat...
ProjectX
posted on 14/2/06 at 10:53 PM Reply With Quote
In answer to which side they go: Longer is O/S (Drivers) and shorter is N/S
BTW no probs in fitting wrong way round. Sierra never (Standard car that is not Cossie) never produced enough power to harm the shafts in normal operation. Metal torque fatigue genarally only applies to larger dimension shafts where the outside is 'twisted' more than the inside due to the centripital forces exerted.
Hope it helps.
J
posted on 14/2/06 at 10:58 PM Reply With Quote
Pat...
im sure jon ison did! If not him, then someone else just before a race.
NS Dev
posted on 15/2/06 at 01:27 AM Reply With Quote
I know of folks that have snapped sierra TRIPOD type shafts on tarmac vehicles, and I know of grasstrackers that have snapped sierra lobro type shafts (for some reason grassers seem to snap shafts more than tarmac racers!??) but I have never heard of a broken lobro shaft on a light tarmac car (i.e. under 750kg)
posted on 15/2/06 at 01:36 PM Reply With Quote
Originally posted by NS Dev(for some reason grassers seem to snap shafts more than tarmac racers!??)
A combination of 12 feet of suspension travel, and the wheels no spending so much time in contact with the ground maybe?
