Canada EH!
posted on 16/2/06 at 01:47 AM |
Upper ball joint size
I have two sets of upper ball joints (steering rod joints) One was sent from the UK as Ford Transit has 200 mm tread, and the taper is much larger
than that of the upright, I think it is too big. The other sourced in Canada has an 11/16 tread and almost fits in the taper on the upright. What is
being used on the book chassis with Cortina upright, and how can I get the proper piece? Thanks.
posted on 16/2/06 at 07:52 AM |
You have a Transit Track rod end what you need is the drag link end -- rh thread
QH part number QD1117RH
As for sources in your continent I am sure someone will post sugestions.
posted on 16/2/06 at 11:38 AM |
Which upright are you using?
The transit drag link coupling is M18x1.5 thread and is nowhere near 200mm ( 8" ) in length. The one you have is M20 I think. What you need
is this
.Look on the lolocost site here .
Canada EH!
posted on 16/2/06 at 02:19 PM |
Sorry about the(200mm) it's 20mm, I grew up in the Imperial measure system, Canada changed to Metric I didn't.
Canada EH!
posted on 16/2/06 at 03:55 PM |
Thanks again gents, just ordered the proper parts from Luego. The 20mm units came from another supplier in the UK., A fellow named Andy Hewing in
Ipswitch.
bob
posted on 16/2/06 at 04:42 PM |
We have been here a few times with this one,its one of the inacuracies in the book that catches a few people out.
Transit TRE on the left and drag link end on the right with longer thread.
Rudy
posted on 8/7/06 at 11:37 AM |
Hi Bob,
your foto is helpful for me!
What is Transit TRE?
The only differene is on the taper?
I try transit drag link but does not fit on insert adaptor, so I think I will need "TRE" bud I do not understand what means TRE.
Sorry for my English
ned
posted on 8/7/06 at 12:04 PM |
TRE = Track Rod End, but you need the rh thread DRAG LINK, the TRE as pictured is a different size.
Ned.
beware, I've got yellow skin
leto
posted on 8/7/06 at 12:15 PM |
There are several different Transit TRE joints, only one will work. Check this PDF-catalog and it
might get clearer. You want two of the SID Ref 2032 I believe you have two 2030.
“I'm gonna ride around in style
I'm gonna drive everybody wild
'Cause I'll have the only one there is a round”. (J. Cash)
Rudy
posted on 8/7/06 at 12:57 PM |
NOW IT IS MORE CLEAR!
THANK ALL
