phil_far
posted on 21/2/06 at 05:57 PM |
Torque settings
Could anyone tell me what Torque settings should I apply for my frpmt wishbones (bolt to chassis brackets) and rea De-Dion (trailing arms to chassis
to Tube brackets)
all bolts are high tensile 12mm
Philip
indykid
| posted on 21/2/06 at 06:26 PM |
you are wrong!
the bush should rotate on the crush tube, not on the bolt. if the bush binds before the crush tube, the tube needs to be longer.
please don't reopen this can of worms - we've had it too many times before.
as for bolt torque, there was a torque list put up a while back. istr about 90Nm for M12 bolts.
hth
tom
indykid
| posted on 21/2/06 at 06:29 PM |
tom
flak monkey
| posted on 21/2/06 at 06:34 PM |
Yes, the crush tube should be firmly gripped in the braket and the polybush should rotate on the tube. Hence why the crush tube is longer than the
polybushes.
Max tightening torque for an M12 bolt is about 85Nm (EDIT - after seeing Toms post, it seems values differ in various sources!!). Though you will find
you might not need it that tight. Its a case of feel (like tightening most fasteners) thats hard to explain, and you learn through experience. Its
worth checking all the critical fasteners after a few miles anyway, as things will bed in and they may come loose.
[Edited on 21/2/06 by flak monkey]
Sera
http://www.motosera.com
shortie
| posted on 21/2/06 at 06:48 PM |
I used the same table and have had no problems, always check after say 500 miles and then regularly.
Rich.
indykid
| posted on 21/2/06 at 07:02 PM |
it's fine with my 19" monitor. get with the times!
it wasn't my pic anyway
and finally, your original statement was ambiguous, and could so very easily start the crush tube debate. AGAIN.
i won't take this any further though
tom.x
flak monkey
| posted on 21/2/06 at 07:46 PM |
Fine on my old fashioned flat CRT 17" monitor running at 1280x1024 as well.
I am guessing your fancy flat panel only runs at 1152x864 at most?
Its not monitor size that determines how much fits across your screen, its the resolution it runs at.
Sera
RichieC
| posted on 21/2/06 at 08:11 PM |
Monitor size is fairly irrelevant, resolution is what makes big things fit in little spaces ;
| posted on 21/2/06 at 08:50 PM |
KY jelly's pretty good too, allegedly . My crush tubes are the same length as my polybushes when they are fitted in the wishbone tube.
Sorry, I'll get my coat before Syd gets here.
indykid
| posted on 21/2/06 at 09:26 PM |
you can run a bigger monitor at higher resolution, but still be able to read the text.
tom
RichieC
| posted on 21/2/06 at 09:55 PM |
Or the same size monitor at a higher resolution to achieve exactly the same, like I say, the size of the monitor is irrelevant.
phil_far
| posted on 22/2/06 at 06:02 PM |
Thanks for the information
Philip
scotmac
| posted on 1/2/07 at 11:55 PM |
I also need to get some torque settings. The chart is good, but i'll need to translate. So, grade 8.8 metric is the same as sae grade 5, right?
And sae grade 8 is metric grade 10.9? So, what is the equiv sae for metric 12.9?
Or, more to the point, what are the torque settings for the various bolts on a cortina front upright?
Thanks, -Scot
