macspeedy
posted on 10/3/03 at 10:08 PM |
Reconditioned calipers
looking around for the best deal on reconditioned calipers for 2ltr sierra who's the best.. cheapest.. ![](/images//smilies/wink.gif)
dodgyroger
posted on 10/3/03 at 10:50 PM |
I read an article in Which Kit recommended Kitfit near Newark (http://www.kitfit.co.uk). They sell recon calipers for £82 outright purchase.
I don't know what they are like apart from the article.
Roger
http://www.dodgyroger.com/locost
bob
posted on 11/3/03 at 12:15 AM |
Have a look at http://www.raldes.co.uk
I think its under O.E calipers,also http://www.rmcarspares.co.uk
bob
posted on 11/3/03 at 12:18 AM |
SORRY
Maybe not RM motor sparesas their prices seem to be drug related
auzziejim
posted on 11/3/03 at 07:39 AM |
bob is the yellow pages letting us down for once! ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/tongue.gif) ![](/images//smilies/tongue.gif)
auzziejim
posted on 11/3/03 at 07:43 AM |
actually on a serious note this is not fair because i need a new caliper these prices scare me!!!! ![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif)
bob
posted on 11/3/03 at 09:17 AM |
JAMES
Because rear cali's are hard to find on sierra's,try your local scrappy for MK3 granadas/scorpios as they seem to be in abundance.
auzziejim
posted on 11/3/03 at 09:28 AM |
calipers
iv already planned a trip to the scrappy for this weekend for a new half shaft and hub carrier assembly and i need a front caliper and maybe a frunt
strut as one of my bolts that holds the suspension strut is stuck as the head came off ![](/images//smilies/mad.gif)
looks like its gonna be expensive ![](/images//smilies/sad.gif)
James
Mave
posted on 11/3/03 at 10:24 AM |
Are the Sierra rear calipers the same as the Granada/Scorpio rear calipers?
progers
posted on 11/3/03 at 10:56 AM |
I have a pair of reconditioned Sierra calipers that I bought from Kit Fit in August. In the end I did not fit them because I went for lighter 4pot
calipers. They cost me £115 for the pair (including carriers) and they are the ones for the larger (260mm) vented front disc.
You can have them for £75, I also have the vented discs to match £100 all in.
e-mail if interested to progers63@btopenworld.com
Paul![](/images//smilies/cool.gif)
eddymcclements
posted on 11/3/03 at 11:34 AM |
Yes - the Granada Scorpio rear calipers are the same as disc-braked Sierras except Cosworth, though.
Picture of my IRS rear with Granny/Sierra caliper and disc in place is here.
Simon
posted on 11/3/03 at 12:36 PM |
Try this:
http://www.lolocost.co.uk/ASPpages/part_details.asp?PartID=42
Simon
bob
posted on 11/3/03 at 02:07 PM |
trouble is they are out of stock of these parts most of the time,as well as that they are not vented discs and wide calipers.
Although i dont suppose it makes much difference with our little cars.
mad4x4
posted on 11/3/03 at 09:49 PM |
I sorry or am I missing the point of this thread.
Why don't you by a pair of calipers from a scrape dealer and then buy a seal overhaul kit from a motor factor. Then, following instruction change the
seals. With the seals out the caliper can be power wire brushed and painted clead up and re-assembled. Can be done in about a hour. Ok so the paint
need time to dry but say yourself £60-80 pounds.
By heating the bleed nipple before removeing will ofter stop it braking. similar to the flexi hose.
We're suposed to be car builders not people who take there car to the garage as soon as we get a problem!.
Scot's do it better in Kilts.
macspeedy
posted on 11/3/03 at 10:14 PM |
Recon
Thanks for the advice, tried my local auto parts store £33.10 inc vat per caliper and £10.11 inc vat per disc (vented non abs) , calipers are on
exchange basis, can anyone beat that !!
carnut
posted on 11/3/03 at 10:37 PM |
Is that just the fronts or the rears as well?
What is this motor factor and where are they?, cos i need to find some but cant find any that cheep.
Viper
posted on 11/3/03 at 10:38 PM |
that must be for the fronts only . rears will cost at least twice that because of the handbrake bit, a real pain apparentley.
bob
posted on 12/3/03 at 08:26 AM |
That price is good anyway for front calipers,where are the factors you use ?
Viper is right about rear cali's,they can be expensive. The repair kit from FORDS is £56+VAT and you cant buy the seals seperate.
[Edited on 14/6/03 by bob]
macspeedy
posted on 12/3/03 at 09:09 PM |
motor factors
Called Pentland components up hear in Edinburgh
mad4x4
posted on 14/3/03 at 10:47 PM |
A Comapny called DINGBRO in Dundee sells the Seals seperatly. But unless you've got a trade account you will have a job dealing with them They stick
by their rule of "Strictley Trade Only"
trebor
posted on 17/3/03 at 07:45 PM |
We bought a seal set for front calipers from the local partico for £20-00. For 240dia unvented front discs they are lucas girling part ref: SP8896.
Had lots of difficulty fitting piston back in though, have only done one, am now thinking would of been better buying new calipers, can get exchange
units for £40-00 a side. mmmmm!
MK7
posted on 14/6/03 at 05:57 PM |
I've found this company to be both low cost and very helpful
http://www.brakesint.com/pages/html/home.htm
Replacement calipers for sierra £25.22 +vat
Rear cylinders £6.31
Front vented discs, around £11 each
They also supply seals and pistons in case you want to recondition your own calipers
Russell
OX
posted on 14/6/03 at 08:02 PM |
i had a set of calipers that were seized solid,so just locked them in the vice heated them up untill near melting point and then used compressed air
to blow the pistons out,tuck the seals out and cleaned out the crap(a spoke with a 90 degree ang at the end and ground a sharp flat point seems to do
the trick),put a new piston and seal kit in greased them up using shinetsu grease and slapped them in,not a problem would not pay any one else to do
it ....a hot spanner is a mans best friend
